06-15-2009
Vikingsailor
Water...will find a way.
So, over the off-season, I worked many hours on our new boat, doing all the fun maintenance chores to ensure they were done, and done right (I hope!)
As the boat had a number of minor leaks, obvious from the water in the bilge and streaks down the hull in a few places, I went through the entire boat & tightened all the hull to deck joint bolts. Also rebedded the deck hardware, replaced portlight gaskets, seacock hoses & hose clamps, replaced stuffing box with a PSS Dripless Shaft Seal, and on and on...oh, and reconditioned all seacocks.
Well, at least I thought I did. After lauch a couple weeks ago, I noticed...AGH!...water in the bilge. Traced it to 3 out of the 7 seacocks leaking around the valve seam where the tapered cone fits into the body.
Nothing serious, but annoying. I've decided to wait for haulout to attempt a repair, which I understand might be done with a valve compound to buff out any small dings that are preventing a good seal
So...how much luck have people had with this process, if any?
The boat is a 1988 Sabre 30...good marine seacocks mounted right...but, leaking...and I understand this is not uncommon with these.
Other than that, she, so far, has been water tight!
It's not whether you're paranoid...it's whether you're paranoid enough.
s/v Cloudman
1988 Sabre 30
