06-16-2009
1979 C&C 30 Mk I - 2QM15
Originally Posted by sailingfool
The proper setting of you topping lift can be found when sailing with the mainsail close hauled...the topping lift should have a little slack in it...i.e. not be restricting the trim of the main.
When the main is lowered, if the boom drops in an inconvenient way, take it up with the topping lift...if not, you haver atopping lift that doesn't need adjusting.
Never take load on the topping lift when the main is raised and being trimmed, especially if you have mid-boom sheeting, or you run the risk of breaking the boom...
Ok... So normal procedure with a topping lift is to leave the tension on the topping lift until the mainsail is raised. Afterwhich, tension should be released and reset so that there's a small degree of slack, allowing the main to hold the full weight of the boom while sailing. Then after the mainsail is dropped, the topping lift can be retensioned to raise the boom just for head clearance.
Correct?
Now here's my secondary concern... I also have a two-line dutchman system running through the main. I don't know a LOT about it, but it would appear to me from the way it's adjusted. That if you allowed the boom to drop more than 6"-8" without disconnecting the topping lift snap shackle that's connected to the upper line, that it would snap both of the monofilament lines on the Dutchman.
Is that the way it's SUPPOSED to work?
