Old 06-17-2009
rocinante33 is on a distinguished road
Fuses for the charging circuit
My charger (Xantrex Trucharge 20) connects to the battery bank with 8 ga. wire and a 30 amp fuse is specified. The 8 ga. is much too big for a standard in-line fuse holder. Blue Seas (among others) has quite a confusing array of different fuse types. I am not sure what the best fuse holder would be for this application. Can anybody advise me on which to use?
While we're at it, what about a fuse (or fuseable link) for the battery bank (2 group 27s wired in parallel)? Any suggestion for a good product which won't break the bank?
thanks
Keith
Rocinante
1983 Ericson 33
Channel Islands, California
Old 06-17-2009
mitiempo's Avatar
For the Xantrex this is a good option from Blue Seas:
MAXI Fuse Block - Blue Sea Systems
For your battery bank this is a good option also from Blue Seas:
SEA Fuse Blocks - Blue Sea Systems
I have used these and they are well made and quite affordable.
Brian
Old 06-17-2009
Whatever you get, and the two Mitiempo suggests are both good, make sure you get extra fuses. Try to limit the number and types of fuses you use aboard your boat to make inventory simpler.
Old 06-17-2009
roline's Avatar
Cal 9.2 SilverSwan
roline is on a distinguished road
Consider the resetable circuit breakers, the series at Blue Seas have a 1/4 x 28 studs for mounting heavy cable. Having a breaker means never having to fumble around looking for another fuse.
Cal 9.2 #19 SilverSwan
Old 06-17-2009
mitiempo's Avatar
I agree breakers are more convenient than fuses, but while a 30 amp breaker is pretty cost effective, the much larger rating for the house bank would be quite expensive in a breaker.
Brian
Old 06-17-2009
Also, circuit breakers are more prone to failure, especially if they're located down by the batteries as they're supposed to be.
Adding Fuse to charging circuit rhadsock Electrical Systems 1 06-11-2009 03:42 PM
The Value of Circuit Breakers and Fuses Chris Brignoli Gear and Maintenance Articles 0 03-24-2003 07:00 PM
