Slideing gooseneck vs cunningham - Page 2 - SailNet Community
post #11 of 18 Old 06-18-2009 Thread Starter
jarcher's Avatar
Originally Posted by pvanv1 View Post
I have a sliding gooseneck on my HR28. That was part-and-parcel with the old-school roller booms of the 60's. Wouldn't replace it like that today, but since it's existing gear, we use it.
We don't use the roller function, but the sliding gooseneck with downhaul is a good thing -- to allow our Dutchman to be tensioned at rest, yet relaxed when the sail is hoisted. We release the vang and downhaul, hoist fully, and then tension the downhaul to adjust luff tension, just like a cunningham.
FWIW, We do run McLube on the gooseneck track, as it isn't as low-friction as it could be.
I'm going to look at the other boats at the marina and see how they have done this. SD raises a good point about boom height changing when controls are run aft. Right now I have no controls run aft that would be impacted by changing boom height, but I would like to run the clue outhaul aft.
Also, my topping lift tends to foul in the top batton, screwing up the shape of the sail. I am thinking of replacing it with a "boomkicker" from:
Boomkicker
If I do install the boomkicker than the gooseneck needs to be fixed at one height. I have not decided yet. I may just need to increase the length of the topping lift so I can release it more.
For now, I am going to look for a way to get any kind of down haul rigged for the weekend. After that the mast is coming down for some work anyhow, so I can rerig the entire thing.
jarcher is offline
post #12 of 18 Old 06-18-2009
bheintz's Avatar
Originally Posted by jarcher View Post
Hi All...
I am trying to modify the rigging for maximum advantage in racing.
Most One-Designs and Handicap rules (such as PHRF) measure the luff length (P: Length from the attachment of the boom to the mast (gooseneck) to the mast's top.) This measurement is usually fixed with a painted "black bands" at the top and bottom. While racing you cannot raise the sail above the upper band, nor lower the boom below the lower band.
Thus to get optimum luff tension easily a Cunningham is by far the simplest.
bheintz is offline
The Following User Says Thank You to bheintz For This Useful Post:
Edward05 (03-19-2015)
post #13 of 18 Old 06-18-2009 Thread Starter
jarcher's Avatar
Hm, another good point. When I applied for my rating I just looked up those numbers for me model boat and didn't actually measure.
So that leads me to ask, how far below the mast head should the top black band be? Once I know that I guess I can measure to see where the gooseneck belongs. I did have in the back of my head that if I replace the track then I am not sure where to locate the gooseneck.
jarcher is offline
post #14 of 18 Old 06-18-2009
I don't discuss my member
zz4gta's Avatar
Leave the track alone, lock it down the next time you're at full hoist and are happy w/ light air sail shape. You'll have to find one design class rules on the luff length and black band measurements.
And just rig a cunningham.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #15 of 18 Old 06-18-2009
christyleigh's Avatar
Jarcher, I also like the "Fixed Boom" idea best but I just thought I'd show an example of how the adjustable boom was done by Seldon (or maybe Nauticat) on my boat's mizzen. Because of the steering station right at the mast a vang wasn't an option (head clearance) so I believe that's why they added the adjustment. Since the boom adjusting slider is held to the mast you wouldn't really need special "car blocks" just secure to the slider on top and mast base at the bottom.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
post #16 of 18 Old 06-18-2009 Thread Starter
jarcher's Avatar
The gooseneck does not lock on the track, but I put an eye on the mast to tie it to for now. The mast is stepped in a small depression on the deck, so I may not be able to get a plate under it. Someone thru-bolted a bail to connect the vang to.
There is a pair of blocks bolted to the deck at the base of the mast which I think are for the reefing lines. I could put similar blocks next to them, one on either side, and run a cunningham line through one, up to the sail cringle, down to the other, then bring them aft with a purchase somewhere. If I do that I can adjust it from either side.
I can do the same with the clue outhaul. Of course the boat's beam is less then 10 feet so it may be over kill.
I don't see this all happening by Saturday but at least I was able to secure the gooseneck so I can tighten the halyard.
jarcher is offline
post #17 of 18 Old 06-18-2009
dgr
jarcher,
A depression? Mine was stepped in a deppression, too. But that was caused by 40 years of rig tension and .... It seems like a real odd design to have a low point on the cabin roof where water could pool.
You can see a few pictures of one way that deck-stepped masts are done in this thread and the work to remove the depression and replace the mast-step and add an organizer plate (oddly enough, the same one that Dog has a picture of.) Finishing up the mast-step repair (lots o pics) - Anything Sailing Forums
Just a Columbia 28
dgr is offline
post #18 of 18 Old 06-18-2009 Thread Starter
jarcher's Avatar
Originally Posted by dgr View Post
jarcher,
Well the depression my mast is stepped in is clearly original. Yes, water does pool there, a little bit. I'll snap some pictures when I next go down there, hopefully tomorrow.
Thanks for that link, it was interesting.
jarcher is offline
Sliding Gooseneck SteveA General Discussion (sailing related) 3 04-30-2009 11:46 AM
boom vang and cunningham. Leland Gear & Maintenance 9 05-20-2008 11:51 PM
Why put a Cunningham on a Genoa? Lancer28 Gear & Maintenance 7 04-15-2008 08:33 PM
cunningham ? Mike244 General Discussion (sailing related) 19 12-02-2007 12:58 AM
Gooseneck Height Problem zaldog Gear & Maintenance 5 07-21-2007 08:53 PM
