LED Mast Lights? - Page 2 - SailNet Community
post #11 of 25 Old 06-18-2009
You need to know what you are replacing. The light may be a replacement some time in the boats life. If you are not positive what it is, plan on a second trip.
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
badsanta is offline
post #12 of 25 Old 06-18-2009
Iroquois MkII
The Series 32 is coast-guard approved. I just bought their stern light to replace my yellowed, cracked, & painted-over stern light.
How did you attach it securely? It doesn't really have mounting screws, just that one expanding bushing you screw into, so it seems like it might need some kind of adhesive too...
LookingForCruiser is offline
post #13 of 25 Old 06-18-2009
jarcher's Avatar
I actually beded it in butyl tape. I do have a concern that the heat will dry out the tape but this is in a non-critical location for leaking, so I can just fix it if it leaks (ie, try another beding compound).
I did speak with David at Aqua Signal about mounting. He insisted that the expanding bushing works very well, but he said if I was not comfortable with it that I could replace the expander with a bolt and just through bolt it.
I used the expander and it does hold very well. I did a bi color at the bow and a light at the stern. The only change I would like to see is a bolt hole on each side of the stern light, and maybe a second one on the bow light, but they do seem to be holding just fine.
jarcher is offline
post #14 of 25 Old 06-18-2009
I have an Orca Green Marine Trianchor light with strobe. It is coast guard approved, draws less than 1 amp. I've been very satisfied.
Not cheap, but very well made.
Orca Green Marine Technology - LED Lighting
sahara is offline
post #15 of 25 Old 06-18-2009
The Bebi lights I mentioned earlier meet COLREG specs. They are not USCG certified, but then they don't have to be in order for us to use them. -my kerosene lantern meets the specs for an anchor light, but I highly doubt it is certified.
By the way, the USCG does not test anything. That is all done by an outside laboratory, which you pay for. The person wanting his article certified has to pass all the tests, and then pay for the USCG to visit the manufacturing facility for quality checks on a routine basis. Bebi is in Fiji, so although I'm sure the Testers would love it, it doesn't make a whole lot of economic sense. This may explain why some companies sell LED mast lights for $400, though
Best Regards,
e
eolon is offline
post #16 of 25 Old 06-25-2009
jarcher's Avatar
Has anyone seen a LED anchor light with a strobe? I know I can get LED tricolor/anchor/strobe, but I don't feel I need tri-color at the mast head. I could get that and just not use the tricolor but that is a waste of money.
jarcher is offline
post #17 of 25 Old 06-25-2009
I disagree. When sailing in heavy seas, especially outside of coastal conditions, the masthead tricolor is a very valuable piece of gear to have aboard. It increases your visibility, since in heavy seas, the deck, level lights may be obscured by the wave crests until someone is almost on top of you. A mast top tricolor is visible a long way away.
IMHO, all sailboats, except inland small lake daysailers, really need both deck level and a mast top tricolor. The reason for this is simple, the deck level lights are necesary when in close traffic situations like in a busy harbor, especially with small powerboats, which don't generally look up...the mast top tricolor is a necessity when sailing in open waters, especially in heavy seas, where deck level lights may be obscured as I said above.
sailingdog is offline
post #18 of 25 Old 06-28-2009
jarcher's Avatar
Okay, you convinced me. I ordered one of the Argo Navis LX Series TriAnchor lights pictured earlier in this thread. I bought one with the tri color, anchor and strobe, and with the photocell to turn the anchor off at dawn.
It arrived Friday. Its a very, very nice light. Its small, relatively light and completely sealed. Sailor's Solutions included a bracket, but I bought the other type of bracket just in case (they said I can return whichever I don't use).
I am, however, disappointed in the strobe. I was expecting it to have a super bright flash tube that could be seen on Mars. I figured that in the worse of circumstances, if I need to be located and rescued, I could turn it on to help people find me. That said, the "strobe" on this device is not useful. All it does it turn the anchor light on and off. Its no brighter than the anchor light, so its of minimal utility.
This device uses 3 wires, as opposed to the one without the strobe that needs only 2. I have already opened it, stripped back the wires and tested it on a power supply, so I'm pretty much stuck with it. That's fine, I'll install it. I already have the triplex wire for it anyhow.
Other than the strobe issue, I am very happy with it.
jarcher is offline
post #19 of 25 Old 06-28-2009
It is my experience, both directly and from several posts in various forums that at least one of the masthead units, the "ORCA", I believe, can't tolerate a hit from a SSB transmission. Two, that I know of personally have been fried on a Single Handed Transpac race last year.
Howard Keiper
Berkeley
thekeip is offline
post #20 of 25 Old 06-28-2009
Splashed
JomsViking's Avatar
The lopolight LED http://www.lopolight.com/ is USCG approved (and expensive) but very rugged.
JomsViking is offline
Southern Cross 31? db27513 Boat Review and Purchase Forum 36 09-02-2016 12:48 AM
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 02:23 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 06:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 09:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 07:08 PM
