well i need some engine help - Page 2 - SailNet Community
post #11 of 19 Old 06-21-2009
Shaken-not Stirred
capngregg's Avatar
I would remove the injector and have it serviced. From your description of the engines run profile, this sounds like the culprit.
Opportunity is missed by most people because it is dressed in overalls and looks like work.
T.A.E.
capngregg is offline
post #12 of 19 Old 06-21-2009
CrazyRu's Avatar
Here is how I would attack the problem.
Remove incoming fuel line from high pressure/injector pump. Attach a hose to a nipple, attach long nosed funnel to another end of hose. (Any hose will do the job, as long it is close in diameter)
Make sure the hose and funnel is clean. Get cleanest fuel, splash it into funnel. Start the engine.
Basically you are running the engine now by-passing most of the fuel system, using gravity feed.
If engine runs fine (chances are 9 out of 10) then you have a problem with fuel supply –lift pump, dirty fuel, bad filters, air is sipping in, something stuck in there..
If engine is not running fine, then, in order of probability
a. Compression
b. Fuel injector
c. High pressure pump
CrazyRu is offline
post #13 of 19 Old 06-22-2009
timebandit's Avatar
When bleeding are you getting air??
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
timebandit is offline
post #14 of 19 Old 06-22-2009 Thread Starter
well after talking to a yanmar guy he says to pull the pump and injector and get em checked out.
as for the ? of air on bleeding yes i did get air after changing the filter but once purged it was just fuel
no compression check check yet, and its a 1gm yanmar, first line in the OP
scottyt is offline
post #15 of 19 Old 06-22-2009
okawbow's Avatar
Had a similar problem on my Yanmar YSE8. I ended up needing a new head gasket and cleaned carbon out of the head, and piston top. Also set the valve lash and injector timing at the same time. It starts hot or cold in a second or two now.
Chuck
Privateer 26 Schooner
okawbow is offline
post #16 of 19 Old 06-23-2009
timebandit's Avatar
Have the valves been adjusted lately?
Rick
Mac 25
Copernicus
Southern California
post #17 of 19 Old 06-23-2009 Thread Starter
no they have not and i cant seem to find a service manual online for free. i have several site that say they have it until you try and its either buy and they dont have it at all
scottyt is offline
post #18 of 19 Old 06-23-2009
Not just a member
1gm
Where are you located? I have a shop manual,compression guage and yanmar experience. I am in southern MD. Let me know know if you would like to borrow anything. Most likely you have a rusted out cylinder head, squirts water in the exhaust valve(very little) it puts the fire out so to speak.
Dan
"Wind Wing"
Piewiet 850 / Dutch Flyer 28
Solomons, MD
Chesapeake Bay
"For the truth is that I already know as much about my fate as I need to know. The day will come when I will die. So the only matter of consequence before me is what I do with my allotted time. I can remain on shore, paralyzed with fear, or I can raise my sails and dip and soar with the breeze."
Richard Bode
-- from First You Have to Row a Little Boat
motovationcycles is offline
post #19 of 19 Old 06-23-2009
Air getting in the system or injector pump, mostly likely injector pump from what you've said here. Pull your pump out and have it tested. I've been a diesel mechanic for 16 years and it sounds like a worn out injector pump.
Chris3492 is offline
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
