shore power battery charger - Page 2 - SailNet Community
post #11 of 13 Old 06-22-2009
mitiempo's Avatar
jarcher is right - you couldn't have started the engine without selecting at least one of your batteries - that's what I get for posting when tired. It sounds like you're fine samhamt.
Brian
mitiempo is offline
post #12 of 13 Old 06-22-2009
AdamLein's Avatar
Originally Posted by jarcher View Post
If it does not have batteries connected to it when it runs then the charging system can be damaged.
Is this true for all charging systems? What about an outboard with an electric AND rope start, started with a pull and with no battery attached?
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #13 of 13 Old 06-22-2009
Most outboards will be fine, provided you either run them without a battery the whole time or with a battery the whole time. It is only when you have a battery and remove it or vice versa that it seems to be a problem .
sailingdog is offline
Battery question Northbeach Gear & Maintenance 9 01-10-2008 11:55 PM
Another battery charger question Omatako Gear & Maintenance 1 09-13-2007 04:23 AM
Battery Charger zaldog Gear & Maintenance 32 08-07-2007 09:47 PM
Paralleling Batteries dave.verry Gear & Maintenance 79 11-27-2006 12:19 PM
Installing a New Battery Bank Sue & Larry Gear and Maintenance Articles 0 09-26-2002 09:00 PM
