Potting & Countersinking - Page 2 - SailNet Community
post #11 of 18 Old 06-23-2009
Irrationally Exuberant
Originally Posted by jbondy View Post
Maine Sail,
I've been seeing the recent references to sealing using butyl tape. Your photos don't show this layer. When using butyl tape, is there a sealant layer under the tape or does the use of butyl tape obviate the need for any other sealant?
TIA
I think some confusion comes from it being called "tape." It's more of a strip of gum-like sealant that is pressed on paper backing. You peel it off the backing as a strip, but it can be manipulated like putty. And as you can see from MaineSails pictures, it is very sticky stuff.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #12 of 18 Old 06-24-2009 Thread Starter
Would you also add a slight bevel to the fiberglass when installing a thru-hull?
cas8100 is offline
post #13 of 18 Old 06-24-2009
Maine Sail's Avatar
No and here's why:
Thru-hulls already have a reverse chamfer or sealant trap built in...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #14 of 18 Old 06-25-2009
Grasshopper
JiffyLube's Avatar
Maine Sail, you're really good at these photo demo's. Is this a hobby of yours or do you do this for a living?
JiffyLube is offline
post #15 of 18 Old 06-25-2009 Thread Starter
Thanks!
cas8100 is offline
post #16 of 18 Old 06-25-2009
Maine Sail's Avatar
Photography is a hobby, sailing is a hobby and gawd no I could not afford boating if this was my lively hood..
______
post #17 of 18 Old 06-25-2009
What about a countersunk screw in a counter sunk hole? I recently installed midship cleats, I over drilled and filled the holes with epoxy then laid in Sicaflex 291 before pulling the cleats down to 1mm from the deck using spacers (I put Sicaflex inside the countersunk recesses) after allowing the sealant to cure, removed the spacers and nipped up the nuts.
Should the countersunk recess and the head of the countersunk bolt have a different angle of countersinkedness (is that a word?) to allow some amount of sealant to remain under the bolthead?
UglyDave
Uglydave is offline
post #18 of 18 Old 06-25-2009
There is little point to putting sealant in the fastener hole in the fitting itself. The area where the sealant is required is between the fitting and the deck, and that is why you're supposed to countersink the top of the fastener hole... since that is where the seal that prevents water from getting into the boat really is.
Also, I would point out that the two-step procedure for allowing the sealant to cure has been debunked. It is very difficult to tighten the fasteners properly without breaking the sealant adhesion them. It is also completely unnecessary if the holes have been countersunk so that the sealant can form a natural "o-ring".
I'd also point out that on high load fittings, like cleats, the two stage cure and tighten process can leave the hardware less than completely tight, since the sealant will resist tightening the bolts as snugly as they should be and lead to premature sealant failure as well as possibly a weaker installation overall--since friction between the deck hardware and the deck caused by fully tightening the through bolts are a considerable factor in the strength of the mounted hardware.
UglyDave
sailingdog is offline
Potting around large openings in deck? jrd22 Gear & Maintenance 15 01-21-2008 11:05 PM
