Lowrance XOG Redux - Page 2 - SailNet Community
post #11 of 15 Old 06-26-2009
While not quite handheld, the older Garmin GPSMap 276 and its successors fulfilled both roles admirably.
sailingdog is offline
post #12 of 15 Old 06-26-2009
Junior Senior
heinzir's Avatar
Location: Lake Minnetonka (near Minneapolis, Minnesota)
I love my H2oC but it recently developed a problem needing factory repair. I called Lowrance to get an RMA and was told the cost would be $165 since it was out of warranty. I can get a replacement on ebay for about $125 so the repair is a no go. The Lowrance tech said that many places were offering the H2oC at closeout prices because Lowrance was coming out with a newer model:
Endura™ Out&Back | Lowrance
They are supposed to be out in July. There are 3 Endura models, with the Outback being the cheapest by far. They are designed for outdoor use and are not particularly suitable for in the car. The primary difference between the models is the amount of mapping software included. Since Sailnet users would probably buy marine charts or lake maps separately it seems to me that the Outback would be the best bet. Tigergps.com is pre-selling the Outback for under $200. You would have to spend another $100 or so for a micro SD with the charts you need.
On the other hand, this may be an opportunity to pick up an H2oC really cheap. The iFinder series and the Endura models are roughly the same size, have roughly the same size screen, and are both waterproof.
Henry
Chiquita - 1974 Macgregor Venture of Newport 23
heinzir is offline
post #13 of 15 Old 06-26-2009 Thread Starter
Unfortunately, despite being older models, the 276C is still a $300-$400 device, it would seem. I would consider it, otherwise, because it looks like it's got the same buttons as my 492C.
Jim
SEMIJim is offline
post #14 of 15 Old 06-26-2009
SemiJim—
The 376 is available for $345... not a bad deal...
post #15 of 15 Old 06-26-2009 Thread Starter
SemiJim—
No, not a bad deal at all. Thanks for the tip! Still: More than we want to spend, I think.
If I can find that h2oC for $150 or so, I think that's the way I'd be inclined to go, at this point.
Jim
SEMIJim is offline
Systems interface - Nexus & Lowrance DwayneSpeer Gear & Maintenance 10 06-02-2009 03:46 PM
Lowrance XOG svey Gear & Maintenance 9 08-24-2008 12:01 AM
Lowrance 250C GPS Question engcon Gear & Maintenance 2 08-04-2007 10:07 PM
Garmin (and others) vs. Lowrance (and others)? SEMIJim Gear & Maintenance 28 07-04-2007 06:29 PM
Lowrance GPS' and Chartplotters SEMIJim Gear & Maintenance 9 06-27-2007 09:38 AM
