06-24-2009
It depends on what kind of sailing you do. If you race, you want a hard epoxy paint that can be wet-sanded. If you cruise, you want an ablative paint that won't build up over time. There are two types of abative paints: the cheaper single season type that will require a fresh coat each spring, and the more expensive multi-season coplymer type that will continue to work after the winter haulout unter it wears off. Any good quality paint should work fine on Long Island Sound.
