Anyone have an Alladin Kerosene Lamp on board? - Page 2 - SailNet Community
post #11 of 17 Old 06-25-2009
Freesail99's Avatar
I did buy a large brass oil lamp and drilled and mount a small DC socket where the wick would go and then I installed a Sensibulb inside of the lamp. I added a decorative chain and use that to run the wires along and hung it over the table in the main cabin. Great light, looks good with low amp draw.
S/V Scheherazade
Freesail99 is offline
post #12 of 17 Old 06-25-2009
Best Looking MALE Mod
Cruisingdad's Avatar
We use one, though I forget who it is made by. It is actually a real anchor lamp and can be used as such. We have always had them aboard and used to use them for light at night without worrying about power. They are also great with a glass of wine.
You can buy the lamp oil at Walmart and it puts out minimum smoke. They do get hot at the end, so be careful before grabbing hold.
Just a word of warning, as I noticed many replies were from campers, on a baot these things get really banged around. Those nice fancy ones with the pretty glass will not last the first storm or Sport Fish.... whichever comes first. Make SURE that it is a nautical grade and if cannot easil (or at all) spill which flipped over, has thick glass, and is well protected. Otherwise your feet will not appreciate you.
I think they have a place on a boat and enjoy mine a lot.
- CD
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #13 of 17 Old 06-25-2009 Thread Starter
Closet Powerboater
MedSailor's Avatar
Originally Posted by WanderingStar View Post
I've only owned mine for six months, but I like it very much. It's bright and quiet, it does not smoke or smell. The mantle was crumbling when I got the boat, I replaced it. The boat was in enough of a sea to bounce the men in the V-berth, the lamp was fine. It does produce radiant heat, we used it to warm and dry in heavy rain.
Wandering star, is your gimbaled or wall mounted? I wonder if that would make a difference to the mantel surviving.
Sounds like they are really finicky... Good to know. The height shouldn't be a problem as I've got about 7' of headroom, and the heat is usually a plus.
Anyone else able to run it for an hour or 2 without fussing with the wick?
MedSailor
MedSailor is offline
post #14 of 17 Old 06-25-2009
I have used antique and modern Alladin lamps most of my 50+ years, at the cabin, camping, and at home during power outages. They do produce quite a bit of heat, and the replacement mantles have become more expensive over the years. With the wick properly trimmed and adjusted, they will burn all evening with the only adjustment being to brighten or dim the light.
The mantles, once lit the first time, become just so much ash, but being protected by the chimney will last a long time with reasonable care.
Hung from the ceiling with a smoke-bell they should be fine in a boat. I would be concerned that the heat produced might be a bit much for gimbaled or bulkhead-mount. We usually keep them a couple of feet from a wall or combustible material.
I usually add about 1/2oz rubbing alcohol to the best kerosene and get very little odor.
YMMV
Donnie
RestlessWind is offline
post #15 of 17 Old 06-26-2009
Mine is fixed mounted to the bulkhead, with a smoke bell. It has a tall narrow chimney. I burn mineral spirits in it, which was recommended by an oil lamp website.
WanderingStar is offline
post #16 of 17 Old 06-26-2009
dgr
CD,
That isn't an Aladdin. That looks like a Den Haan kerosene anchor light.
From my understanding, there are at least three functional types of kerosene lamps
1) A liquid candle, like what CD is showing.
2) A petromax style pressurized one. Most people are familiar with a Coleman camping lantern
3) An Aladdin. It is non-pressurized but has a mantle like the pressure one. The wick sits below the mantle and the flame burns inside of the mantle and causes the mantel to incandesce
Just a Columbia 28
dgr is offline
post #17 of 17 Old 06-26-2009
dgr,
you are correct with the three different types of kerosene (coal oil) lamps. I also have a #2 in brass. What a beaut, and what noise.
Lighting is fun, check the fuel level, pressurize. Fill the cup with alcohol, light, wait for it to almost burn out, turn on kero and hope the generator is hot enough to vaporize it. Insert ear plugs. Produces light and heat comparable to the Coleman white gas lanterns. Mine is a single mantle.
man that thing is loud!
meuritt is offline
A Simple Fender Board sailingdog Gear & Maintenance 6 04-28-2009 10:55 AM
kerosene/thinner? wiseleyb Gear & Maintenance 18 02-12-2009 04:04 PM
An all-purpose settee berth GoodOldBoat Gear & Maintenance 0 12-06-2007 08:51 AM
Fire on Board! Don Casey Seamanship Articles 0 07-14-2003 08:00 PM
Kerosene Running Lamps Sue & Larry Gear and Maintenance Articles 0 07-04-2002 08:00 PM
