Riveting? How does this work? - Page 2 - SailNet Community
post #11 of 14 Old 06-27-2009
An Aussie Sailor
Mipcar's Avatar
When I did some riveting on my old boom. My rigger told me to use Monel pops.
Mychael
Mipcar is offline
post #12 of 14 Old 07-01-2009 Thread Starter
So I used Stainless steel pop rivets and they broke off as soon as I hit a close haul. Clearly that wasn't strong enough to hold. I guess I should have mentioned that I sail in the SF Bay where 20kt winds are standard.
I'm thinking of drilling through the boom and putting a bolt in through the middle and using a boom bail, like CaptKermie recommended. Any suggestions on good ways to do this, things to avoid?
Will I hit anything as I drill through the boom? What's inside there?
Thanks guys
dsimon1044 is offline
post #13 of 14 Old 07-01-2009
tommays's Avatar
The part poping off makes no sense as 3/16 SS rivets have a 1000# + shear each OR the part does NOT use enough rivets
One big issue is what grip range of rivet you used as to short OR to long would cause problems also
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #14 of 14 Old 07-01-2009
If I'd of read this when first posted I would have told you that rivets are a poor choice for a vang mount especially when the are loaded in tension. They work quite well in shear but unless they have back washers they will fail in most tension applications.
They only thing that may be in the boom are the fott and reefing lines. Don't drill through when mounting the bail rather layout and drill from each side. You may be able to take the end cap off to look don the boom also .
Good luck.
jfdubu is offline
Boatyard Discussion Cheetie Gear & Maintenance 59 03-19-2009 10:31 AM
Work while I cruise? Internet question gskgsadz Cruising & Liveaboard Forum 1 08-09-2008 08:41 AM
Work needed in Daytona Beach FL wduncan50 Gear & Maintenance 9 12-20-2007 08:41 AM
Trade work for boatsit in SF Bay Spring 2002 kunyefish General Discussion (sailing related) 0 11-12-2001 06:29 AM
Refitting an Older Boat Sue & Larry Gear and Maintenance Articles 0 12-16-2000 08:00 PM
