- SailNet Community
post #1 of 2 Old 11-20-2002 Thread Starter
Thanks to all who take the time to keep up this message board. As a new sailor, it''s been VERY helpful!
I''m the new owner of a 1988 Catalina 30 TR with the M25XP engine. When she was hauled for the winter a few weeks ago, I noticed a spot in the joint between the keel and fiberglass that was "weeping" water. It lasted for more than a week. The yard says to tighten the keel bolts and paint. Does anyone know how much to torque the bolts? Should I just paint over it in the spring after it has had a chance to dry out? Dig out the fairing material and replace (with what)?
Also need to install a new cutless bearing. I have read what I can and it all seems pretty straight forward. But, engine/shaft re-alignment, can anyone walk me through the process? I''ve read about repacking the stuffing box with teflon "flax". I have seen both the "flax" and a putty material. What''s best? What size flax do I use? It might also be a good time to replace engine mounts. How much of a job is this?
And last, any favorite web sites to purchase cutless bearings, fuel filters (both Racor and engine), engine mounts, etc.
Thanks again,
Mike in Noank
dargiem is offline
post #2 of 2 Old 11-20-2002
I sugest you join the Catalina owners'' association and order a copy of their tech notes. Most every maitenance task is covered.
Sailmc is offline
