Chainplate rebedding with mast up - Page 2 - SailNet Community
post #11 of 32 Old 06-26-2009
Not Finished Yet
RainDog's Avatar
Sorry, I meant 3M 4000, not 3M 5200. I agree 5200 would be a very bad idea.
RainDog is offline
post #12 of 32 Old 06-26-2009
That's a different story. much better choice...
sailingdog is offline
post #13 of 32 Old 06-26-2009
Originally Posted by josrulz View Post
My main question is, do I need to disconnect lowers on both sides evenly, or is it OK to leave them on one side, but disconnect the other to work on them? I wasn't sure if the lop-sided pull would be problematic, or OK for a few hours of work.
I would recommend first easing all the turnbuckles a few turns just to take the strain off. Then you will have no problem removing shrouds either in pairs or singly. Halyards aren't really necessary, but they sure can't hurt. Sometimes, you can hook the shrouds back up temporarily to the rail too. Just don't load em up.
knothead is offline
post #14 of 32 Old 06-26-2009 Thread Starter
Unpaid Intern
josrulz's Avatar
I did mine with 3M 4000 UV. I did the first chainplates and all the stancions on Saturday. On Sunday I reattached the lifelines and the upper shrouds and rebedded the lower shroud chainplates. Monday I just had to reattach the lower shrouds and tune the rig. 101 has a longer cure time than 5200. I would not want to load the rig until the sealant cures, but maybe I am just being superstitious.
I've been told before that with 3M 101, you want to load everything up before it cures anyway (just relaying info here). As one Sailnet member stated at the time, if you're chainplates are moving enough to break the seal, then you have bigger problems than choice of sealant.
I rebedded a very leaky chainplate with 3M 101 this spring, a few days before the mast was stepped. We sailed the boat offshore to get her home in pouring rain and waves, and have since had days on the Chesapeake, pounding to weather with green water over the decks. That chainplate still isn't leaking.
Of course, that's no scientific test--it was only been a few months, and I'm no expert here. But I'll try this again, and see how it goes. I'll report back if I run into problems down the line.
Sooo, any votes on whether I should remove the lowers on BOTH sides at the same time, or can I do one side at a time and leave the other side connected? Or does it matter?
1984 Sabre 34 Mk I
josrulz is offline
post #15 of 32 Old 06-26-2009
SD, How do you figure that 5200 isn't flexible enough to bed chainplates? How big a gap do you leave around them anyway? I'm holding a cured chunk in my hands right now. Squeezing it between the jaws of my Leatherman. The stuff feels like a piece of rubber.
If you have a gap of about a 32nd to an 1/8 of an inch around the plate, how could it not work?
knothead is offline
post #16 of 32 Old 06-26-2009
hell i sailed my boat home with out an upper shroud, granted i did it under a reef and no head sail and 5 knot winds
scottyt is offline
post #17 of 32 Old 06-26-2009
How old is that chunk, the stuff loses flexibility and elasticity as it cures and ages...
post #18 of 32 Old 06-26-2009
mitiempo's Avatar
I think the best reason not to use 5200 is that it's so adhesive, if you ever have to remove it (and you will eventually) that it will pull gelcoat off underlying glass structure. Sure you want the sealant to stick to what you're bedding, but not to that extent. 5200's 700 psi is not needed, 4000/4200's
300 psi is plenty.
Brian
mitiempo is offline
post #19 of 32 Old 06-26-2009
Exactly... and for something like chainplates, where the fit depends on the strength of the pieces, and does not rely on sealant for strength... butyl tape is an excellent choice, since it is very elastic and sticky, but not very strong.
300 psi is plenty.
Brian
post #20 of 32 Old 06-27-2009
Midwest Puddle Pirate
US27inKS's Avatar
I tried several of the sealants mentioned in this thread. Butyl tape finally sealed it for good.
John USYacht 27 "Cora Lee"
US27inKS is offline
Southern Cross 31? db27513 Boat Review and Purchase Forum 36 09-01-2016 11:48 PM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
