Old 06-28-2009
Guidera48's Avatar
Guidera48 is on a distinguished road
Help repairing deep scratches
I am the new proud owner of a Hunter 37 cutter. This boat has a bad case of dock rash and has deep scraches in several locations on the starbord side.
I very familiar with automotive fiberglass repairs and fillers, however I am not familiar with marine product names. Can anyone sudgest what to use as filer and primer?? Eventually, the boat will be repainted after all repairs and upgrades are completed.
Also, the bottom is pressure washed and cleaned but does not look good. The boat has been out for 8 months and should be dry. Since it is going to be on the hard for several months, in a public area, ( my business rear parking lot), I wanted to paint it for apearance sake. I dont want to paint it with antifouling paint yet. Is there an other paint that I can aply to have a protective coat and be able to apply the required fouling paint before launching??
Thanks
The faster I go, the more she likes it!!
Jose Guidera
Old 06-28-2009
Guidera48's Avatar
Picture of Hull
Sorry I missed this picture
Jose Guidera
Old 06-28-2009
scottyt is on a distinguished road
well for filler there are lots of options. the simplest route is gel coat paste from west marine, thicken it some with micro balloons. or epoxy with micro ballons, either way use a spreader to apply the paste you make to fill the scratches. it will take several coats with sanding and degreasing/dewaxing in between. i would use micro balloons so its easy to sand smooth, then a rolled on finish coat of what ever you used un thickened as a sealer, that you can block sand smooth, then paint.
if you go back here and search there are lots of posts on this. if you want click on my user name and view all my posts there are a few threads i have given better more complete info on as have others in the same threads
Old 06-28-2009
Guidera48's Avatar
Thanks
Thanks for your suggestion. I will resarch your threads,
Jose Guidera
Old 06-28-2009
http://www.sailnet.com/forums/gear-m...-openings.html
http://www.sailnet.com/forums/gear-m...ent-wrong.html
http://www.sailnet.com/forums/gear-m...ll-damage.html
http://www.sailnet.com/forums/gear-m...ss-damage.html
http://www.sailnet.com/forums/gear-m...g-gelcoat.html
Old 06-28-2009
Don't use microballons if the scratches are below the waterline. Use colloidial silica..
Old 06-28-2009
SD the pic he put up in the second post looks like it right below the toe rail.
Guidera if you use the silica make sure you dont leave it very proud of the the surface the silica is like sanding rock, it takes a while, and is very hard to do with out sanding down the surrounding gelcoat
Old 06-28-2009
Yes, I'm aware of that... I was just pointing out that below the waterline you don't want to use microballoons.
This is true.
Repairing Scratches on Outside and Sail Repair Help sailor93 Gear & Maintenance 2 04-21-2009 10:29 AM
Repairing scratches SkywalkerII Gear & Maintenance 5 09-05-2008 06:28 AM
Repairing Gelcoat Cracks and Chips Don Casey Gear and Maintenance Articles 0 11-06-2002 07:00 PM
A Deep Sump Tom Wood Gear and Maintenance Articles 0 02-22-2002 07:00 PM
Repairing Holes in Fiberglass Dan Dickison Buying a Boat Articles 0 09-20-2001 08:00 PM
