Old 06-29-2009
castoff is on a distinguished road
Genoa sheet question
When I bought my Valiant 37 the genoa sheets were 3/4", to big for the Barient 28 ST winch. How does one decide on the size of sheet to use. How would I find the recommended sheet size for the winch?
Old 06-29-2009
DwayneSpeer's Avatar
Old Fart
DwayneSpeer is on a distinguished road
Sheet size
Use what feels good in your hands and doesn't slip thru the self tailers.
Hey, can one of you guys pass me a crab?
Old 06-29-2009
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Holy moley!
I should think so. 3/4" would probably be too big for the Harken 40s on our boat.
It's a trade-off between size and hand feel. Bigger-diameter lines are easier to get a good grip on, but they're heavier, take up more space on winches, and are more expensive.
I don't know as there is such a thing.
We're using 7/16" StaSet for jib/genoa sheets because 7/16" was what we were replacing. There's also a set of 3/8" sheets in the locker, which would probably be better for the light air genoa.
Our main halyard is 7/16" something-or-other, and it works fine on our #28 cabin-top winches.
Jim
Old 06-29-2009
davebkanelavie is on a distinguished road
I'd use 3/8" line for sheets. Yes, it will be a little harder on the hands. But, easier to store the line, better for light air, and it will run through the blocks easier and best of cheaper.
If you have self tailing winches or rope clutches sized for the 3/4" line it would be wise to check that the smaller line will grip ok.
David Kane
Old 06-29-2009
Sabreman's Avatar
Sabreman will become famous soon enough
Half inch Sta-Set workes well for our 38'. See "http://harken.com/calculators/GenoaLoading.aspx" for loading calculation.
Sabre 38 "Victoria"
Trimming Your Asymmetrical Spinnaker sandygoodall Seamanship Articles 14 03-31-2010 09:27 AM
Undersized Genoa dgr Gear & Maintenance 9 08-06-2008 10:00 AM
Sheet Winch Question? STLMac21 Gear & Maintenance 23 08-23-2007 08:02 PM
Adjustable Sheet Leads Brian Hancock Seamanship Articles 0 02-08-2002 07:00 PM
Adjustable Sheet Leads Brian Hancock Gear and Maintenance Articles 0 02-08-2002 07:00 PM
