Old 06-30-2009
nereussailor's Avatar
Coastal Traveler
nereussailor is on a distinguished road
Send a message via Yahoo to nereussailor
Fender Boards
I am considering making some fender boards so the pilings don't eat my boat.do any of you out there use them and if so, what are the approximate dimensions of the boards you use.
Dave
Old 06-30-2009
MMR's Avatar
MMR MMR is offline
MMR is on a distinguished road
Send a message via AIM to MMR
Search the forum for "fender boards" There was a previous discussion just recently. I've tried to put a link in but can't get it to work...
s/v Patience Two
Gemini 105MC
Old 06-30-2009
I started one a while back... LINK
Old 06-30-2009
billyruffn's Avatar
billyruffn will become famous soon enough
BR has fender board similar to the one Dog described in his link above -- 2" x 8" x 8', except we didn't bother with using PT wood. We've sailed 25,000 miles with the fender board lashed to the rail on the stbd bow -- we've used it twice.
After all those miles our board has a nice silvery patina, is very soft to the touch and, most importantly, it contributes to BR's "look" as a serious crusing sailboat -- just what you want in a fender board.
PS. It also is very good at trapping dirt in the scuppers.
PPS. If you double click on the avatar you can see it there on the stbd rail. Very 'salty', eh?
Old 07-01-2009
SVAuspicious's Avatar
Mermaid Hunter
SVAuspicious is on a distinguished road
Where will you keep the board? The determining factor of the length is usually storage. Mine are about 5 feet long and have been plenty.
What loads will they take? When weather deteriorates I get out of the slip and on the hook. YMMV. Absent serious weather, a 1x6 is plenty big enough. If you are going to weather hurricanes in the slip (assume doubled lines, chafe protection, yadda yadda yadda) maybe - MAYBE - you want a 2x6. If you are in an exposed location, thicker boards make sense.
I put the holes for lines just a few inches from the end of the boards. This has made keeping the fenders inside the ends of the boards more reliable.
sail fast and eat well, dave
S/V Auspicious
AuspiciousWorks.com
beware "cut and paste" sailors.
Old 07-01-2009
Cruisingdad's Avatar
Best Looking Moderator
Dave
I used a 2x6x8 treated. Two holes in each end and dangled from the lifelines with fenders on the inside. When I did not need it as a fender board, it worked as a boarding ramp (until someone stole it... now who would steal a freaking boarding ramp!!!!???).
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 07-01-2009
CaptainForce's Avatar
I've made much of use of my fender board.
You might think from the spider web that they're not used, but we've very quick working spiders aboard!
This board is about four & one half feet long with three stainless strakes parallel across the center were the board would face a piling. 'does a great job! 'take care and joy, Aythya crew
Old 07-01-2009
Coastal Traveler
Thanks everyone, I installed one fender board tonight that was built like SD's diagrams. I tied it off to the toe rail with the fenders behind it on the hull. I ended up using a 2x6 that I cut to 5' it's going to work out great for my slip. I'll store it on deck if I can, or in the aft berth with the rest of the sails and such.
Right now, it kind of looks out of place, it needs the weathering so it looks more at home on the boat.
Next project....... outboard motor mount on the aft rail for the dinghy motor.
Old 07-01-2009
Glad to help.
Old 07-02-2009
Just a comment, maybe not necceesary, but will make regardless: If you have serious tides, the board CAN ride up over the fenders. THe result is not pretty, as you can imagine from this finish:
I have not fix for it... only to say that it only happened on unusual circumstances with extreme tides. Just a warning to watch out for your boat.
Brian
Com-Pac 16
Fender Skirts: A Risk-Free Introduction to Canvaswork Don Casey Gear and Maintenance Articles 0 11-24-2002 07:00 PM
The Art and Science of Fendering Sue & Larry Learning to Sail Articles 0 02-27-2000 07:00 PM
The Art and Science of Fendering Sue & Larry Seamanship Articles 0 02-27-2000 07:00 PM
The Art and Science of Fendering Sue & Larry Gear and Maintenance Articles 0 02-27-2000 07:00 PM
The Art and Science of Fendering Sue & Larry Cruising Articles 0 02-27-2000 07:00 PM
