fuel additive problem? - SailNet Community
Blogs
Old 07-02-2009
baboon is on a distinguished road
My 3 cyl diesel has only failed twice in the 15 years it has been used. Both were the same situation. About 20 mins of run time after filling the tank the engine stops. No smoke, no alarms, no low oil pressure, no evidence of overheating, just quits. The racor bowl is clear, no water or gunk. I pumped fuel out of the bottom of the tank, it looks perfect. The first time (last summer), after towing the boat (30 feet, 6000 pounds) back to the dock with me rowing the dingy, a great work out by the way, I got it started by just cranking for awhile. I purged the fuel system and replaced both filters just to be safe. After that it ran perfect for a year ON THE SAME FUEL until today when I put 8 gals in the tank. Then it did the same again. It would re-start, run a few secs, then died. The third crank it ran fine all the way home.
I am wondering if the culprit is the biocide I put in the tank just after filling both times. It is pretty thick stuff. My theory is that it settles to the bottom of the tank and after the fuel in the line and 2 filters is burned. It then enters the engine without enough dilution and the engine will not run until it is pumped through by cranking and stumbling for a bit. Has anybody had a similar problem? Any other ideas?
Thanks
Old 07-02-2009
scottyt is on a distinguished road
if you are right add the biocide first, then fill. the fuel flowing in might help to stir it up
Old 07-02-2009
patrickrea's Avatar
patrickrea is on a distinguished road
That is correct. You should always add anything before the fuel so that it has a chance to mix. Fuel pickups are at the bottom of the tank.
Patrick Rea
1978 30' Hughes Northstar 1000
1964 20' Bertram Moppie
Old 07-03-2009
preservedkillick is on a distinguished road
There was an article on fuel bioicides in the latest Practical Sailor. Could it be that you have an tank infestation, and then a bunch of dead bugs that precipitate out after you add the additive?
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30:
Old 07-04-2009
With the most recent case I added fuel then additive to a tank that was already one half full. If I am correct the additive would have to settle to the bottom through all that fuel before being sucked into the intake. Does that seem plausible?
As to dead organic material being the culprit, I think it should be filtered by either the racor or spin on engine filters. It also should show up in the racor bowl. The filters are not clogged. Is it possible the buggers are so small that they would pass through both, pass through the motor and make it die, but not clog the injectors or leave any other trade of being there?
I am new to diesels and appreciate any input,
Thanks.
Old 07-05-2009
badsanta is on a distinguished road
unless you have a bug problem, I would not use any additive. Next time you fill up dont use it and see what happens. Already happened twice, doing the same thing and it stopped twice. I have always been taught to use nothing but clean fuel, but if you do add something to add it first then add the fuel.
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
Winterization List: How to Winterize? Step-by-Step Photos? captxtina Gear & Maintenance 8 10-25-2008 11:12 AM
Engine will not rev above 2,100 RPM Ilenart Gear & Maintenance 26 06-05-2008 10:44 PM
Universal M21, long story and fuel line question BarryL Gear & Maintenance 16 05-12-2008 04:37 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 08:00 PM
Diesel Fuel Concerns SailNet Gear and Maintenance Articles 0 07-08-2002 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
