07-06-2009
Well a 27 foot sloop has what, a 30 or so foot mast? So you're saying the light is 10 feet up or so? I would leave it there. The requirement is that the steaming light be 1 meter (about 3 feet) above the red/green/stern lights, so you got that beat. As SD always points out, lights too high in a crowded harbor can confuse people who are not looking up, but 10 or so feet is not too high.
Also the lower it is the better the deck light will work, as long as the beam is not too narrow. But the Aqua Signal 25 deck light is not super directional.
And, I doubt the headsail passing over it will be an issue. There is nothing for it to catch on with this fixture. If you really want you could put one of those cages over it. My boat has one, but I would not have added it if it was not there when I bought it. All it does is make changing the festoon steaming bulb hard because the cage gets in the way of opening the fixture. Not fun while dangling from a halyard.
So don't make more work for yourself, just go ahead and install it and call it a day. Just my 2 cents, others may have a better idea but I think this is straightforward.
PS - I just happen to have my mast down right now and just went through more or less the same decision making process.
