Old 07-06-2009
corny is on a distinguished road
Ladder recommendations
We have a Ranger 28 and are looking for a good ladder for climbing down to our dinghy and for emergency MOB situations. Having a little difficulty in selecting one...interested in hearing what others have devised, purchased or both in the ways of 'swim' or 'boarding' ladders. Pics, mfg info, etc. would be nice.
Old 07-06-2009
CaptainForce's Avatar
The ladders are nice for getting aboard from a swim, but for dinghy access we use the little (approx. 8"x8") pad suspended by four lines that is in the West Marine catalog. It's very stable and can give you the distance between and rib bladder and the deck to make it an easy step. 'take care and joy, Aythya crew
Old 07-07-2009
roline's Avatar
Cal 9.2 SilverSwan
roline is on a distinguished road
I had a ladder that fit over the toe rail, but was not mounted for everyday use. I prefered the transom mounded ones for always being there for a possible MOB recovery. If you are overboard it is too late to think about finding the ladder in the lazerette and installing it on the toe rail. I looked on the internet and Ebay for months and finally found one for under $100 delivered. WM has several versions abailable, but none were a fit for the transom on the Cal 9.2. It mounted with 4 1/4x20 screws, just needed to add an access port on the inside of the cockpit to access the nuts and mounting washers. It pivits down and extends into the water far enough to be able to stand on. I tried the emergency Plastimo ladder, rope with plastic rungs, it just was not practicle requiring too much upper body strength. If the water is cold, you need an easier way...
Cal 9.2 #19 SilverSwan
Old 07-07-2009
Joesaila's Avatar
1977 Morgan OI 30
Joesaila is on a distinguished road
Big Help!
We have a 'swim' ladder that can be used to get in the boat from the dinghy. But, I appreciated learning about the Quick Step from WM. [inexpensive too]I'm sure it will work better than the swim ladder and the person won't have to duck under the stern rails. I'm getting one today! This post was a big help since my wife has a hip injury
My formula for living is quite simple. I get up in the morning and I go to bed at night. In between, I occupy myself as best I can.
Cary Grant
Old 07-07-2009
Gary3675 is on a distinguished road
I would look for a ladder with flat steps. The round steps hurt your feet....if you are bare footed. For comfort and ease of use the wider the step the better.
Old 07-07-2009
Be aware, if you need a swim ladder to get back aboard, make sure it has at least TWO STEPS below the water... I'd also point out that amidships mounted ones are far safer in heavier conditions than transom mounted ones.
Old 07-07-2009
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Overton's® > EZ On Jet Step Flexible Ladder
I'm going this route, as I don't normally swim with the jellyfish, and its cheap, light, and stows nicely.
Merit 25 # 764 "Audrey"
Old 07-23-2009
Thanks for this recommendation! I stopped in at a West Marine store in Madison, WI and looked one over. I thought, 'I can do this for under $10!' Then I went home, got a piece of 1x8 lumber, sanded, drilled holes, stained and spar varnished it, and applied 3M non-skid tape. Grabbed a couple of shackles and some line and headed for the boat. The result? A very stable, strong step. I'll post photos next time I'm at the boat.
The line is one continuous line. It starts with a stop knot in one corner, goes up to a shackle with a bowline, back down to the same ends' forward corner, then under the step and across to the other forward corner, then up to the other shackle and a bowline, and then back to the other rear corner with a stop knot underneath. It's fairly easy to adjust to the boat and your hook-in points, just make sure to tie it so that the lines form more of a right triangle than an isosceles triangle...there should be a definate front and back so that the step lies relatively level and tight against the hull.
Old 07-23-2009
Freesail99's Avatar
Freesail99 will become famous soon enough
Recommendations for a ladder for a boat with a dinghy davit with solar panels mount on top of the davit. Any suggestions, I am not spider man anymore.
S/V Scheherazade
Old 07-24-2009
Go with one that mounts amidships instead of at the transom. You'll have to walk the dinghy forward to the ladder, but it would be far simpler to board the dinghy that way.
Paint Recommendations svkestrel2 Gear & Maintenance 4 01-15-2009 10:50 PM
Where to install my ladder? SSBN506 Gear & Maintenance 5 08-01-2008 02:23 PM
O'Day 23 boarding/swimming ladder svey Gear & Maintenance 2 06-25-2008 02:36 PM
mounting a ladder to a transom cnc33voodoo Gear & Maintenance 7 06-12-2008 12:59 AM
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
