07-06-2009
Furling Problem
Hi all, I am having an intermittant problem with my furler. It is one of the old ones with a separate top and bottom, and no foil joining the two. I don't see any brand markings on it. My current problem is that when I furl my 150 genoa the bottom begins turning well before the top, leaving me with a tightly rolled lower end and a very loose upper. This leaves the top of the sail to catch some wind while at the dock. I have tried applying more pressure (and less) on the sheets while furling the sail. Sometimes things work fine and other times, like now, it doesn't. I have tried tightening the halyard and loosening it to see if that helps. I don't see much difference. I should add that I usually do this solo, so maybe that is the problem?
Any suggestions are very welcome.
Thanks, Bill
1988 C36 "Wild Wind"
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
