Old 07-07-2009
jarcher's Avatar
jarcher is on a distinguished road
Do you leave your reefing lines rigged all the time?
Do you leave your reefing lines rigged at all times? I am going to re-rig my two line reefing system and I am wondering if these lines stay rigged.
It seems from all the talk about reefing from the cockpit that they would stay rigged, but it seems that having reefing lines running from the aft end of the boom up the leech of the sail would interfere with air flow?
Old 07-07-2009
celenoglu's Avatar
celenoglu is on a distinguished road
They should be kept rigged all the time. It is nearly impossible to pass the line through the eye on the leech when you need it.
Old 07-07-2009
bloodhunter's Avatar
ex-Navy
bloodhunter is on a distinguished road
Leave em rigged
As a test, try rigging the lines when you're tied up at the dock. Then imagine trying to do that when the wind kicks up enough to make reefing necessary. You're right, they do interfere a bit with the air flow but you gotta have them ready when you need them.
You might also practice reefing the main on a nice calm day to a point where you and your crew can practically reef in your sleep. Better than trying to learn in a 30-kt wind and a choppy sea.
Old 07-07-2009
Yes... if you really want to clean up the air flow, get higher tech lines of a smaller diameter for the reefing lines. 3/8" polyester double braid, which is commonly used on many boats up to about 35' LOA has a breaking strength of about 4000-4400 lbs. 1/4" T-900 has the same breaking strength but far less windage and weight aloft.
Old 07-07-2009
rikhall's Avatar
old guy :)
rikhall will become famous soon enough
Bloodhunter is right on. Once you can do it at the dock try it without leaving the cockpit - then try it when you have a beautiful day with 5 - 10 knot winds. Then try it all by yourself with no help.
When practicing - try it in your foul weather gear with harness and tether.
When that storm comes up from behind, catches you by surprise and the winds and rain are coming at you sideways - it is a PITA to try and figure out a seldom used system.
Me - it is easy - the commodore looks out before we leave and sometimes says - "please put a reef in."
I have found:
  1. life is much nicer when I listen to her and comply
  2. it is much easier to shake a reef out than to put one in
We have left harbour with a "not needed" reef in on more than one occasion, but Linda is also quick to realize we did not need it and to suggest we take the reef out.
Cheers
Rik
Irwin Citation 34
Old 07-07-2009
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
I am having trouble with this tread. Lets get real, just how much speed can reef lines cost you. Worrying about disturbing the air flow of your sail by reef lines, are you that good of a sail trimmer that this would make a deference.
I sail with 2 jiffy reef lines that always rigged and beat boats with better PHRF's than my boat. If my reef lines cost me a 1/10 of knot (which I doubt) so be it. I do know that when I need to take in a reef, I am not thinking about that 1/10th.
Never Forgotten
Old 07-07-2009
KRCSWO is on a distinguished road
I race regularly on 2 different boats.
First boat has 2 reef points in the main. We keep the first reef point rigged all the time. The 2nd reef line has a stopper knot tied at the end of the boom so that it just needs to be attached to the sail if needed.
Second boat is a OD racer. They remove the reefing lines and replace them with very light weight lines that can be used to fish the proper reefing lines through when required. This lowers weight and windage on the sail plan. But I think it is getting a little picky. Then again, they tend to win a lot of races, so......
Old 07-07-2009
NON member
AE28 is on a distinguished road
Our boat, an Alerion Express 28, has two sets of reef points, with single line reefing set up for the first reef only.
We leave the line in place.
Paul
Old 07-07-2009
tommays's Avatar
On the J24 i allways have then IN as the wife does not like heeling
On the 35' boat i also race on the race main does NOT even have reef points BUT we only use that sail on short races and have a HD main for distance racing
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 07-07-2009
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
I keep them rigged in the boom w/ high tech/light weight line and hooks pliced to the ends. When it pipes up, unload the sail, hook onto the horn at the tack, then hook in the reefing line at the clew. Easy to do with your eyes closed, no windage and low weight.
Merit 25 # 764 "Audrey"
Dead Reckoning Calculations Jim Sexton Learning to Sail Articles 0 04-27-2004 08:00 PM
The Basics of Reefing Mark Matthews Learning to Sail Articles 0 03-29-2004 07:00 PM
Hold That Line Tom Wood Gear and Maintenance Articles 0 10-03-2002 08:00 PM
How Other Sailors Learned Mark Matthews Learning to Sail Articles 0 08-31-2001 08:00 PM
Here’s the Rub Don Casey Seamanship Articles 0 11-15-1999 07:00 PM
