07-07-2009
5411 Gets Hot
I have a Universal 5411, no heat exchange. My problem is slightly different from the other hot threads.
When I start the engine, and keep it at low revs, no water comes out the exhaust, and she goes over 180 degrees. But, if I rev up the RPMs, she will pump SOME water and stabilize at 162 degrees. 12 degrees too hot (if the gauge is correct).
I can't determine if;
1) I have an air leak
2) impeller is worn.
3) Thermostat needs replaced (NO water until 160 degrees)
4) Partial blockage some where.
Would anyone care to give me a start?
