Old 07-07-2009
countdemonet's Avatar
Ruler of Wind and Wave
countdemonet is on a distinguished road
Help ID this Rope Clutch
Folks,
What brand and model is this rope clutch? There may be some markings on it but I'm away from the boat and need to find some maintenance info. Vintage is 1990.
Pearson 34-2
"I don't know where I am but I know I'm not lost"
Old 07-13-2009
OK. I'll answer my own post. Here's the email reply to an inquiry I made to Garhauer.
"This is a Garhauer product. This is an obsolete part and replacement parts
are not available."
Pearson 34-2
Old 07-13-2009
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Look at spinlock
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 07-14-2009
I'd rather be sailing
labatt will become famous soon enough
What clutch to replace them with is like having a "Which anchor is best" conversation. We have the Lewmar D2's and like them - almost no slip when engaging under heavy load and easy to open under heavy load. I also like the fact that they open towards you. Anyway, practical sailor did clutch reviews recently so you might want to look up that article. I'm surprised to hear Garhauer doesn't have replacement parts for those ones...
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
Old 07-14-2009
PalmettoSailor will become famous soon enough
You can get nearly identical Garhauer clutches from Catalina Direct. It looks like you have four singles there, but you could do two doubles or a triple and a single to get all four lines covered. These clutches look like something out of a tractor factory but they are affordable, strong and durable.
Catalina Direct: Running Rigging
PalmettoSailor (formerly midlifesailor)
s/v Palmetto Moon
1991 Catalina 36
Old 07-14-2009
JT1019's Avatar
Belliure 41'
JT1019 is on a distinguished road
Send a message via AIM to JT1019
It is a Spinlock. Call Chuck at Sound Rigging in Essex CT, he has all the info on how to rebuild them.
“Greatness Is Not In Where We Stand, But In What Direction We Are Moving. We Must Sail Sometimes With The Wind And Sometimes Against It – But Sail We Must, And Not Drift, Nor Lie At Anchor.”
Oliver Wendell Holmes
Old 07-14-2009
Regarding singles vs. doubles vs. triples... We have Lewmar D2's which have to be sized for the line going through them (usually allows a 3mm variance in line size). I don't know if all clutches are like that or not, but with singles you can replace individual clutches if you change line sizes. We just did that a few months ago when we ran a third reef and had to swap out two clutches. Using the singles, we could just swap out the two and not have to swap out the entire bank. I know you can just replace the innards, but it only took me about 3 minutes per clutch to unscrew the old one and screw in the new one.
Old 07-15-2009
IMHO, the best line clutches are the Lewmars. The mechanism they use is the easiest to adjust under even the heaviest load and does the least damage to the lines. Spinlocks can often jam under high loads, requiring you to ease the load on them using a winch prior to releasing them. They are also among the least expensive of all the line clutches.
However, Lewmars, due to the "domino line clutch mechanism" they use, have the smallest range of line sizes they can handle, and need to be sized appropriately for the task.
Be aware that the Lewmar line clutches open in reverse compared to many other brands... and note the little winch icon and arrow on the line clutch when installing them.
Rope mats GoodOldBoat Gear and Maintenance Articles 13 12-11-2011 08:42 PM
Rope Clutch or Jam/Cam cleat for traveler? T37Chef Gear & Maintenance 13 03-26-2009 04:24 PM
Lewmare Super Lock or Spinlock XAS Rope Clutch? zz4gta Gear & Maintenance 6 08-19-2008 08:11 PM
How to size rope ModMMax Gear & Maintenance 41 12-12-2006 12:16 AM
Hold That Line Tom Wood Gear and Maintenance Articles 0 10-03-2002 08:00 PM
