Old 07-09-2009
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
sticky traveller
... no I'm not talking about Smack's visit to NY.
I have a traveller that sticks in the same position it's in. I had to run the line back to one of the big winches to get it to move-- and that was with a loose mainsheet.
What should I put on it to help it slide freely, even when the mainsheet is tight?
Old 07-09-2009
BarryL's Avatar
BarryL is on a distinguished road
Hi
McLube Sailkote is what I use.
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
Old 07-09-2009
lshick is on a distinguished road
Send a message via Skype™ to lshick
If you're in a saltwater environment, start with floods of fresh water.
Larry Shick
V42-148 "Moira"
Old 07-09-2009
smackdaddy's Avatar
Last Man Standing
Bene, dude, your boat's a freakin' basket case!
Love,
The Sticky Traveller
PS - Sorry I emptied your 1 gallon margarita bottle while I was there.
Old 07-09-2009
14432's Avatar
14432 is on a distinguished road
Brand & age of traveler?
McLube is good stuff but may not work in every case
Old 07-10-2009
When was the last time you removed the traveller car and did basic maintenance on it??? Might be a good time to start. Forcing stuff using a winch is generally a bad idea.
Old 07-13-2009
Don Radcliffe
donradclife is on a distinguished road
Probably a Lewmar traveler, best replaced with a Harken.
Old 07-16-2009
SoC SoC is offline
SoC is on a distinguished road
This is late in coming and what responses you did get weren't of much use. You didn't mention what type of traveller it is. McLube, though a good product, it is not recommended you use it on Harken ball bearing cars. Because of the load patterns on the bearings, it can actually cause the bearings to slip (not spin) and not work as designed, you should just make sure to keep it clean. Also if you have a large purchase in your system with a marginally oversized double braid line it can create problems. The core of the line twists within the jacket and causes it to bind as it rounds the sheeves. I have a Harken 6 to 1 system with 3/8 StaSet tag lines and it binds all the time creating a problem like you describe. Apparently the solution is to go to a smaller line or one of the same diameter only single braid, like Bzzz or Salsa.
SoC
Lewmar Traveller Shortman Gear & Maintenance 12 03-22-2009 07:35 AM
Sticky rubber on Bino trantor12020 Gear & Maintenance 2 01-19-2009 08:57 AM
When to use the traveller saurav16 Learning to Sail 18 08-28-2007 05:03 PM
What is the point of a traveller? dwbecker Learning to Sail 9 09-25-2006 08:35 PM
Moving Traveller Forward ( Mirage 26 ) Oor Wullie Gear & Maintenance 0 02-03-2002 11:50 AM
