Joinery Separation - Help - SailNet Community
post #1 of 1 Old 11-21-2002 Thread Starter
I made the mistake of buying a Hanse 311. They are a German made sailboat. I have some questions about sailboats and I was hoping someone here could help me.
Most of the joinery work down below is separating. The forward bulk-head wall, the wall in the head and the entire galley sink are all separating from the cabin floor. The galley sink is a good 1/2 inch removed from the cabin floor, maybe more.
This is a Brand New boat!! Correct me if I am wrong but this should not be happening on any sailboat much less a brand new boat.
And I e-mailed Hanse in Germany. They told me that I was worried about nothing and I should just apply some SikoFlex epoxy to the effected areas and I should be OK.
That is NOT an answer. Squirting glue into a 1/2 crack is not going to fix anything.
My questions are this. a) What would cause something like this to happen? b) How can you re-attach the walls and the galley to the cabin sole? As I said squirting more epoxy does not fix it. c) How do you prevent something like this from happening again? d) Have any of you out there had similar problems with any of your sailboats and if so how did you fix it?
mqh7 is offline
sailnaway General Discussion (sailing related) 53 12-21-2004 04:00 PM
Joinery Separation - Help mqh7 Boat Review and Purchase Forum 1 11-21-2002 02:13 PM
Joinery Separation - Help mqh7 Gear & Maintenance 0 11-21-2002 09:21 AM
Joinery Separation - Help mqh7 Gear & Maintenance 0 11-21-2002 09:20 AM
Joinery Separation -- Help mqh7 Gear & Maintenance 0 11-21-2002 07:53 AM
