Old 07-11-2009
jarcher's Avatar
jarcher is on a distinguished road
length of spinnaker sheets?
Hi All, how long would sheets be for a traditional spinnaker on a 30 foot LOA boat?
Old 07-11-2009
Hudsonian is on a distinguished road
60'
Old 07-12-2009
JimsCAL's Avatar
JimsCAL is on a distinguished road
I agree with Hudsonian. Rule of thumb is twice the boat length.
Old 07-12-2009
blt2ski's Avatar
I would swag 2 35-40' sheets. As the tack and the clew will be near the bow, then lead dang near to the back of the boat, then you need some length for getting too, then around a winch, along with tailing. My AS spin sheet is 85' for a 30' boat, and I have maybe 3-4' too much on the ends if that!
Marty
She drives me boat,
I drives me dinghy!
Old 07-12-2009
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
35' would definitely be way too short for a symmetrical (I assume that's what he meant by "traditional") kite on a 30' boat. 40' would be marginal, IMO. On a close reach the guy will come from forward of the bow, back to a turning block at the stern, then forward to winch and cleat. 45' would be the minimum, I would think.
But I'm just a n00b at flying a kite, so what do I know?
I'd buy 60' each. If they're too long you can cut off the excess and use the spare line for something.
Jim
Old 07-12-2009
jarcher's Avatar
Yes, I meant symmetrical. Probably should have said that, but it was late and my mind was apparently not in full gear. Thanks everyone, I'll get some 60 foot sheets.
Old 07-12-2009
blt2ski's Avatar
I should probably have said 35-40' minimum! per sheet.
Also, being as you are going to race, many folks will have 1/4-5/16" for windy days, and a higher strength 1/8" for light wind days! Then there will be clips on the sail ends for quick change outs if the wind pipes up or down!
Marty
She drives me boat,
I drives me dinghy!
Old 07-12-2009
jarcher's Avatar
Marty
A good light air spinnaker sheet is NE Ropes flight line, because its light, strong and if it goes in the water it won't soak it up. But, if you use it on a heavy air day, it will melt on the winch.
Since spinnaker sheets are pretty much constantly being adjusted, I would think any good 8mm (5/16) line would do. That's good, because 120 feet of high tech line would not be cheap. I'll probably use Stay Set.
Old 07-12-2009
mgmhead's Avatar
Somewhat Senior Member
mgmhead is on a distinguished road
My Sabre is a 34 footer and the spin sheets are 85' of 3/8" Sta-Set. Don't short yourself.
MGM
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
Old 07-12-2009
Use of high performance line as spin sheets and guys really pays off. It will not be uncommon for the distance between the clew and the winch to 45'. If a gust of wind were to cause the sheet to stretch 4% that means 22" of stretch. Wouldn't you rather have the force of the wind pushing your boat forward rather than just stretching a sheet?
Using stretchy lines for guys is even worse. High tech lines will help you avoid having the pole hitting the forestay everytime you have a puff while on a close reach.
On your size boat 5/16" Samson Ultralite should do the trick. Don't go any smaller; your crew won't be able to handle thinner sheets.
Spinnaker Takedown Basics Dean Brenner Racing Articles 0 04-28-2002 08:00 PM
Spinnaker Fundamentals Steve Colgate Learning to Sail Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Seamanship Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Gear and Maintenance Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Racing Articles 0 06-24-2000 08:00 PM
