Cabin Fans - Page 2 - SailNet Community
 2Likes
post #11 of 19 Old 07-14-2009
Best Looking MALE Mod
Cruisingdad's Avatar
I agree that the cafamro (sp??) are better. Dad has the Hellas and we move more air.
However, I also replace a bunch of blades, including just his last weekend. All but one time it was due to the kids playing with them or not paying attention. If they hit something that stops the blades for any period of time, they basically melt the plastic inside and you are going to end up replacing the blade.
- CD
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #12 of 19 Old 07-14-2009
Anybody used the Caframo 747/757 model? Its the one with no guard, just the blades. I was checking fans at WM this past weekend and it seemed to move the most air of the models they had on display. It was also very quiet which is why we are considering replacing the fans on our boat.
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
PalmettoSailor is offline
post #13 of 19 Old 07-14-2009
I just bought a couple at walmart. About 12 inches square. You can put batteries in them or use a 120 volt plug. The great thing it the transformer reduces the power to 12 volts so I cut the 120 volt transformer off and installed a 12 volt plug. Works great, quiet. Not high quality but for $20 works great
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
badsanta is offline
post #14 of 19 Old 07-15-2009
Closet Powerboater
MedSailor's Avatar
I have owned the hella "boat fan" (not the turbo), on the last boat. I hated running them because of the noise. They stood up well though.
Would definitely look for something quieter this time.
Another option is to use computer case fans
They are cheap ($2-20), there are a million types and they all run on 12v so you just hook them up to a switch and go. Better still since silent and low power draw computers are all the rage they always list their cubic foot per minute flow rate, their db sound rating and amp draw. They are available from 1.5"-6" or larger. Not all look the same either. This one is 8" diameter "silent" and $22:
Or this 14inch monster, which moves 129CFM silently(22db) drawing 500ma
Google "computer case fan" or try PC Case Fans and Cooling Fans at Xoxide.com - Computer Case Fans
MedSailor
MedSailor is offline
post #15 of 19 Old 07-15-2009
It depends on where you are mounting them. The Caframo Boras are a better fan and have three speeds and an electronic switch versus the two-speed Hella Turbo and a mechanical switch, but for bulkhead mounting, the Turbos are better, since they pivot at the center of the fan diameter, rather than the base.
Originally Posted by fireman181 View Post
I am in need of several fans and want opinions on air flow and current draw.Fans are for the cabin of a C & C 32', deciding between the Caframo Bora Fan, and the Hella Turbo......any recomendations........Thanks
sailingdog is offline
post #16 of 19 Old 07-16-2009
HerbDB's Avatar
I have been using these Guest fans for years. A little pricey, but they move air and can be set to oscillate.
Herb DuBois
Beneteau 36CC
Split Decision
HerbDB is offline
post #17 of 19 Old 10-25-2012
Re: Cabin Fans
I would find it very usefull if Medsailor could post a couple of photo's using the cpu fans
S/V Arabesque is offline
post #18 of 19 Old 10-25-2012
chef2sail's Avatar
Re: Cabin Fans
We have these Caframo 2 speed no gaurds....none needed.....55 amps..moveable especially with additional clip..279cfm max air moved, hard wired or 12v plug
advantages----moveable, can use plug, and easiest to clean ( all fan blades get dirty its amazing). Can store them out of the way when not in use
CAFRAMO Two-Speed Compact 12V DC Fan, White at West Marine
Caframo Boras- also good...... .27 amps. fixed , hard wired 275 cfm max air moved
CAFRAMO Bora Three-Speed Fans at West Marine
Caframo Scirraco
also good .25 amps, fixed mount, hard wired 240 cfm max air moved
CAFRAMO Sirocco Cabin Fans at West Marine
Hella
Not as powerful. .1amp draw, fixed mount, hard wired,150 cfm air moved
HELLA MARINE 12V & 24V Turbo Fans at West Marine
dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #19 of 19 Old 10-25-2012
Sumner10's Avatar
Location: Utah (House & Macgregor 26 Classic) -- Florida (Endeavour 37)
Re: Cabin Fans
We tried those...
....and were not happy at all.
We have a number of the Caframo on both boats and really like those. We use....
....the ones with the timers in the V-berth. A lot of nights we just need the air while we go asleep so we set them on the 2 hours and they go off then. As we moved into summer we went to 4 hours then 6 then 8.
You can also position those...
...to any direction you want.
We hardly ever run them off of low and they don't use much more power vs. ......
...the very inefficient CPU fans. .21 amps for the Caframo vs. .13 amps for the CPU fan above. There is no comparison on the air they move. You can only feel the CPU just inches from you and the Caframo from feet away.
There is more info and pictures on the CPU and the Caframo on our site here....
Macgregor 26S Inside Mods page 31
Last summer Home Depot had the open face Caframo's on sale for $25 and that is when we bought about 6 that we use around the cabin during the day.
I'm going to keep a couple in the boat that will run when we are gone to help with mildew protection. They will be on a low voltage cutoff relay that we got for not much money and they will turn on/off according to battery level and we have solar on the batteries,
Sum
Our 37 Endeavour --- Our 26 MacGregor --- Trips With Both
sww914 likes this.
Sumner10 is offline
placement of cabin heater rrgane Gear & Maintenance 8 02-15-2008 11:28 AM
Proper Cabin Lighting Tom Wood Gear and Maintenance Articles 0 02-24-2003 07:00 PM
Proper Cabin Lighting Tom Wood Cruising Articles 0 02-24-2003 07:00 PM
Proper Cabin Lighting Tom Wood Her Sailnet Articles 0 02-24-2003 07:00 PM
