Old 07-16-2009
jvarner222 is on a distinguished road
Adler Barbour Cold Machine
I have a AdlerBarbour Cold Machine about 5 years old. I can't get it to start when it above 75 degrees outside. The unit is under the cockpit in a morgan sailboat. I am getting a single led flash which is to show low voltage. However, I have new batteries, charging unit is fine. I am geeting 12 volts to the unit. When the unit tries to start it will draw around 20 to 22 amps for about 2 seconds and then shut down. When it is running ok it will pull around 12 amps. It will try again after a bit but do the same with no go. I have checked the voltage everywhere and all looks well. Any one with any ideas. Thanks Jeff
Old 07-17-2009
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
Start looking at your electrical connections. Something is corroded or not tight. It is drawing to many amps at start, that is resistance.
Never Forgotten
Old 07-18-2009
JiffyLube's Avatar
Grasshopper
JiffyLube is on a distinguished road
Sounds like a problem I had, and a new controller solved that.
Old 08-10-2009
Mondofromredondo
mondofromredondo is on a distinguished road
Adler Barbour
I'm having the same problem with mine.
I guess the first thing I'm gonna try is running new wires directly from the battery to make sure I'm providing adequate voltage and amperage.
Keith
Old 08-11-2009
btrayfors will become famous soon enough btrayfors will become famous soon enough
If you're only getting 12V at the AB, then either your wiring is too small or you have some bad connections (loose or corroded terminals, loose or corroded nuts or screws, etc.).
Try that first.
Inrush current can be much higher than the run current, even if the compressor is working properly. Normally, it's only for an instant or two before the compressor gets rolling, whence the amperage draw will drop to about 3-6, depending on the compressor.
If your compressor starts when the engine is running, that's a sure sign that there's a bad wiring connection somewhere.
Bill
Adler Barbour refrigeration Fro36 Catalina 10 08-13-2010 08:42 AM
Adler Barbour Water Cooled Refrigeration bobbosax Gear & Maintenance 1 12-26-2008 10:27 AM
Adler Barbour PSI? recycle Gear & Maintenance 2 06-01-2008 10:59 PM
Adler Barbour maintenance ZapataII Gear & Maintenance 5 05-07-2008 12:01 PM
Alder Barbour Cold Machine Electronic kd6mzm Gear & Maintenance 1 07-15-2006 12:28 AM
