-   -   Loud Crack Sound at Night (http://www.sailnet.com/forums/gear-maintenance/56297-loud-crack-sound-night.html)
JeffBurright 07-17-2009 04:53 PM
Hi all,
I was wondering if this sound I hear in the evenings is normal. I live on a wood/epoxy/glass composite sailboat with a fiberglass deck in Seattle, and nearly every night I'll hear a single loud crack coming from the direction of either the deck, the side hull, or the window housing (it's a single large sheet of poly-something adhered and bolted in place).
My guess is that it has to do with the expansion and contraction of one of these components as the day cools off, but it's loud enough to be startling and a little worrisome. Do other folks experience this? Should I worry about the wood cracking or some other kind of separation taking place?
Thanks,
AdamLein 07-17-2009 05:04 PM
Do you have a neighbor with poor docking skills?
wwilson 07-17-2009 06:05 PM
Jeff,
I sail a fiberglas boat slathered with mahogany in its innards and (unfortunately) teak on the deck. Occasionally I hear a similar, "pop" that is the difference in expansion, or contraction between the dissimilar materials. Unless the "pop" precedes a frantic bilge pump, I'll bet your noise is from similar source.
Wayne
Vasco 07-17-2009 07:03 PM
The dreaded pistol shrimp again!!! But only one this time.
JeffBurright 07-17-2009 07:31 PM
Oh Jeez, I had to wiki the pistol shrimp. Thanks for the new nightmares.
Vasco 07-17-2009 08:46 PM
Have you looked at the you tube video?
SEMIJim 07-18-2009 01:53 AM
Shrimp that "pack heat," one could say :p
Jim
OhioTom 07-18-2009 02:14 AM
My guess would be the window housing you mention. A large sheet can expand and contract quite a bit over the temperature change between night and day. If its bolted on, it could be that there is not enough flexibility in its mounting and that is causing the sound. Are there any cracks?
