Old 07-20-2009
Barking Dog
KindOfBlue is on a distinguished road
DC Generator Continious Output Question
A DC genset has a spec of 200A at 12V. What does this mean with respect to charging my batteries?
For instance if I have 600AH house bank and I run down to 50%, how long will I need to run the generator to top off my bank? Is it 1.5 hours or is there a 3 stage regulator needed to charge, accept and float my batteries back to 100%?
Craig
Old 07-20-2009
mitiempo's Avatar
If your batteriers are lead/acid their acceptance rate is about 25% meaning that the max they will accept is 150 amps. This is called bulk charge. This will continue until they are about 80% charged and then it slows down for acceptance. At about 95% it changes to a float charge. So the first stage is fast and the last 20% will take hours with any charger. If your batteries are AGM they will accept a greater charge in bulk mode. This is why when offshore and charging with engine only people seldon get past 80% capacity and use between 50% and 80%. Wind generator and solar can of course change this.
Brian
Old 07-20-2009
Barking Dog
That totally makes sense. Thanks!
Craig
Old 07-20-2009
k1vsk will become famous soon enough
That makes sense only if the voltage is sufficient to charge, regardless of current rating. As an example, my DC generator output is around 13V. As the voltage is insufficient to charge, it could produce a thousand amps and NEVEr charge the batteries quickly.
Without knowing it's output voltage, you can't draw any conclusion.
If you mean what you said literally, i.e., 200 amps at 12V, it will not charge anything.
Old 07-20-2009
mitiempo's Avatar
That's true. Charging voltage is about 14.2 and 12 is a battery with about 40% charge remaining.
Brian
nmea output from Raymarine Graphic j34035 Gear & Maintenance 15 11-03-2008 06:05 PM
anchoring question rperret Seamanship 24 07-18-2007 09:28 PM
racor question rperret Gear & Maintenance 8 06-19-2007 01:18 PM
Shore power question Omatako Gear & Maintenance 23 04-13-2007 10:33 PM
question on sails Mark_OD23 General Discussion (sailing related) 6 11-19-2002 04:41 PM
