07-24-2009
I would point out that using a screwdriver on the turnbuckle body is a really stupid idea, even if a lot of people do it. The turnbuckle bodies are not designed to resist such lateral forces and if the threads are seized, could be damaged. Most turnbuckles have a flat area that is designed for a wrench to be used on, to apply any necessary torque. Be sure to use either TefGel or Lanocote on the turnbuckle threads to help prevent corrosion or galling.
