DIY davit or lift? - Page 2 - SailNet Community
post #11 of 13 Old 07-24-2009
TEAM ZISSU
drobarge's Avatar
for the traditionalist john is on the right track with oak. Hickory, ash or southern yellow pine are also good choices. Most of the load in his design would be compression so 2.5 in square should be enough for a couple hundred pounds, if the bases are well secured. You should check the backing on the gallows bases also.
"who za sheet is kingsley zissou"...claus R\V Bellefonte
drobarge is offline
post #12 of 13 Old 07-24-2009
TEAM ZISSU
drobarge's Avatar
p.s. john, trans oil was only down afew tablespoons at hilton head :-]
drobarge is offline
post #13 of 13 Old 07-24-2009
If you want to use PVC pipe, you could fiberglass over it and then probably get something that is strong enough to work. Personally, I think stainless steel is the way to go.
sailingdog is offline
Davit Problem; Expert Needed danielgoldberg Gear & Maintenance 20 05-09-2016 06:28 PM
Topping Lift and Sail Shape NCC320 General Discussion (sailing related) 13 02-24-2011 11:25 AM
Solar Panel Mounting On A Davit Freesail99 Gear & Maintenance 8 08-14-2007 03:22 PM
Boat lift in a storm knothead General Discussion (sailing related) 5 08-27-2006 11:24 PM
Keel Lift NJW3 Seamanship & Navigation 6 09-22-2003 07:59 PM
