Fresh Water cooling water dirty brown - Page 2 - SailNet Community
post #11 of 18 Old 07-30-2009
Just do an online search for Yanmar parts, Yanmarhelp.com, or Yanmarmarine.com, or for part numbers call Torreson Marine.
By the way, your impeller has definitely seen better days and should be replaced.
k1vsk is offline
post #12 of 18 Old 07-30-2009
garymcg's Avatar
ebay
Current yanmar part number is 124223-42092
I picked up a couple on ebay for $19.95 each but I don't see any on there currently. Torreson has them for $33.74:
Yanmar 124223-42092 Ships Store Torresen
Gary
garymcg is offline
post #13 of 18 Old 07-30-2009
RichH's Avatar
How long has this engine been sitting idle?
"Brown" coloration of the cooling water is most probably a symptom of the antifreeze's rust inhibitors being consumed. In cast iron engine blocks the normal course of action is - the constantly flowing HOT water produces a layer of 'black' or 'blue-black' ferrous rust ... and this is protective. Upon long standing and without repeated heat/hot cycles the ferrous oxide slowly converts back to "red" or ferric oxide which is destructive. Long term storing such an engine by draining it (but leaving high humidity in the cooling passages) is the worst possible scenario with respect to ferrous to ferric oxide formation.
Suggest you drain the brown water, refill with at least 50:50 mix of antifreeze/water .... then RUN THE HELL OUT OF THE ENGINE (hours and days) to be sure that you redevelop the important 'black' ferrous oxide (black rust) layer inside all the cooling passages and channels; make sure that the engine is 'soaked' with 180 def. F water temp.
If the engine HAS been recently and long term been run hard and hot .... change as above and if the discoloration reappears, .... then check for a 'blown head gasket'. Your local 'automotive machinist shop' can give you 'tips' on adding a 'blacklight' dye to the water, etc. to check for blowby carbon monoxide/dioxide in the cooling water ... from a blown head gasket.
RichH is offline
post #14 of 18 Old 07-30-2009 Thread Starter
Crealock 37
sailak's Avatar
Dock
Rich,
I just bought the boat in May. It had been out twice before I took possession. It had probably set since Sep or Oct of the year before (long stinkin' winters up here ).
I've run it quite a bit. Several times of motoring for 2-3 hours at a stretch (I use 2600-2800 RPM for cruise).
Would a head-gasket problem show up in the exhaust as well? smoke perhaps? I haven't seen any symptoms of any problems, other than ugly coolant fluid.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #15 of 18 Old 07-30-2009 Thread Starter
Crealock 37
sailak's Avatar
Dock
Those large scars I think are from the grips when I removed it.
So those little striations along the edge of the paddle are a big deal? Or is there something else you're seeing that I don't?
Thanks
Dale
S/V Elnora
sailak is offline
post #16 of 18 Old 07-30-2009 Thread Starter
Crealock 37
sailak's Avatar
Dock
That's what I found searching the 'net. The part I put in was a -42091 - which I'm not finding any reference to but matched what I took out (it was in the spares kit for the boat).
Dale
S/V Elnora
sailak is offline
post #17 of 18 Old 07-30-2009
RichH's Avatar
Originally Posted by sailak View Post
Rich,
Not necessarily if the leak is very slight but enough to pass high pressure combustion gases into the cooling fluid. Notice any liquid level drop in your reservoir tank? if so the suspicion for a blown head gasket somewhat increases.
RichH is offline
post #18 of 18 Old 07-31-2009 Thread Starter
Crealock 37
sailak's Avatar
Dock
Thanks Rich
The coolant level is holding steady, no indication I'm losing coolant.
About that sea water pump...what is the pump body made of? It looks like brass or bronze, I'm wondering because I want to get some spare screws and want to minimize the chance of corrosion. As I understand any dissimilar metal is a bad idea.
Dale
S/V Elnora
sailak is offline
Raw Water Cooling System Questions morgantheship Gear & Maintenance 19 11-17-2008 07:07 PM
A-4 no water thru cooling - starnesent Atomic 4 6 08-20-2007 03:43 PM
Fresh water and head HoffaLives Gear & Maintenance 5 05-13-2007 09:46 PM
Connecting raw water cooling to water heater Northeaster Gear & Maintenance 18 04-28-2007 06:11 PM
Flushing/testing/preping an old water system on a new old boat tenuki Gear & Maintenance 8 04-19-2007 10:33 PM
