-   -   Using Formica (http://www.sailnet.com/forums/gear-maintenance/5649-using-formica.html)
bantrybayboston 11-25-2002 12:21 PM
Using Formica
Does anyone have any experience replacing formica surfaces on the inside of your sailboat. Can you use standard formica methods (like you would in your kitchen)? Can you formica over formica?
Thanks
Kevin
clayton 11-26-2002 09:19 AM
Using Formica
Yes,you can formica over formica. I did my entire galley over (but I pulled off all the old stuff using a heat gun). Be careful of the fumes from some types of glue, measure carefuly, dry fit first and use dowels between the glue surfaces to help with the fit.
Good luck.
