So, you guys have been such an amazing help everytime I've asked a question, I figured I'd ask another ... It probably won't be my last
I want to run the halyards aft in my Starwind 22 - a trailerable sailboat with a swing keel, and a mast I can lower with the wife.. because i single hand pretty often. We don't race, just goof around in the bay.
So here are my ?'s
1) what kind of loads are we talking about here ?? I want to run the halyards through blocks at the base of the mast, and then through cheek blocks to make the 90, then cam cleats.. everything is rated at 400-600lbs.. is that enough (I can leave the existing cleats on the mast base just in case the sh!t hits the fan and the cams blow out.. although pretty unlikey)
2) I oversized the halyards to make them easier to handle. I can't remember what was recommended, but the sailing guy at WM suggested I go up to 5/16 for ease of handling..the blocks I want to use (Harken Carbo 29's) have a max line diameter of 5/16.. is it cool to use the max line diameter for the block, or should I reduce the line to the original recommended ?? ( keeping the blocks @ 29 saves 50% of $ of upsizing to 40's)
3)don't use foul language in response to this one.. I recently saw an image of a similar boat using clam cleats instead of the more fancy pants and modern cam cleats to secure the line.. what are your thoughts on that ?? ( i would prefer gold and diamond spinlock organizers, labeled in neon, but it's just not on the cards..
Again thanks for all your help !!
~Joey
