-   -   Removing 3M 101 from fasteners (http://www.sailnet.com/forums/gear-maintenance/56638-removing-3m-101-fasteners.html)
OhioTom 07-29-2009 01:03 PM
I'm re-coring my deck and have hundreds of fasteners I want to reuse that are slathered in 3M 101 or equivalent caulk. What is an easy way to strip all the caulk from the fasteners?
I'm soaking a few test pieces in mineral spirits. What will get it off easily (dissolve it) without reacting with the stainless steel?
Thanks.
doubleeboy 07-29-2009 03:16 PM
dsmylie 07-29-2009 03:51 PM
Once cured you will have to use mechanical mens. A dental pick or similar device works pretty well but depending on how many you have to clean it could be very labor intensive. I always just replace the fasteners, but then again I have not removed all my fixtures at one time. Good luck.
David:)
timebandit 07-29-2009 06:37 PM
Soft wire wheel on a bench grinder.
