Old 08-07-2009
bluesky2 is on a distinguished road
Dishwasher & washing machine
Just wondered whether anyone has dishwasher and washing machine on their boat?
I notice my dishwasher uses hardly any water and gets everything very clean.
Likewise for modern washing machines.
Any thoughts on what the minimum size boat that could easily handle these two appliances. e.g. would 42' to 46' work in monohull?
Anyone have or seen a boat (monohull <46') with a dishwasher and a washing machine?
Any thoughts on what boats work work well these?
Last edited by bluesky2; 08-08-2009 at 04:46 AM. Reason: Any boats with dishwashers out there?
Old 08-07-2009
Cruisingdad's Avatar
Best Looking Moderator
The issue for most sailboats (and most boat sin general) is not just the power draw or water consumption, it is the space the items take up. Space is a premium. My boat is over 40 feet, and I could not find a place for it.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 08-07-2009
I hate washing dishes and I like the shiny clean you get from a dishwasher, so my next boat will need to be large enough to fit one. I have noticed there are small size dishwashers which would be adequate and take up less space.
I don't need a second head so this spaces would be spare and would have all the plumbing.
Old 08-07-2009
Big Chicken Baby
Mimsy is on a distinguished road
I hate washing dishes as well. A few years back I was living in a tiny 1910's bungalow that did not have a dishwasher. I had one of these and loved it-
★ Countertop Dishwasher SUPERSTORE - TOP Online Specialty Store - HERE ONLY! Largest selection of table top dishwashers at discount prices
Its not much use for large pots and pans and if you are trying to clean dishes for a party of 20 you will probably end up just doing them by hand rather than keep using for the 72 hours required to run enough cycles to get it all cleaned but for day to day light stuff they are great.
S/V Ceol Mor
42 Nassau
Our little blog has moved!
Old 08-07-2009
I don't need a second toilette so this spaces would be spare and would have all the plumbing.
Be aware that even the small ones will probably take a generator. The one referenced below took 10.4 amps. That is a lot of power and diesel just to keep from washing a few dishes. I am just saying, that's all. It would probably be fine at the marina though if you could find a counter to fit it
Com-Pac 16
Old 08-08-2009
Power Consumption
I am looking at a Zanussi (Electrolux) ZSF 2420.
Normal cycle:
Water: 7 Litres
Washing time with drying: 94mins
Drying time: 13 mins
Energy: 0.8Kw (800 watts)
Fuse:13amps
Vac: 230VAC/50Hz
Heating Element: 1000w
Power rating 1080w.
So 800watts/230V=3.4Amps for 1.5 hours = 5.2 amp hours
So 5.2 amp-hours and 7 litres of water seems pretty reasonable.
The size is fine for two people and can fit pots and pans etc.
Old 08-08-2009
damies's Avatar
damies is on a distinguished road
well you have ignored inverter costs, but all up I would expect it to be less than 8 amp hours (I would have trouble believing an inverter would use 2.8AH for 1.5 hours use). Still seems reasonable to me. But I wouldn't bother with the dishwasher (don't even have one at home). Anyone got details on a washing machine? That would interest me if I was living aboard.
Can you use them with salt water and only use fresh for the final rinse? Also where does your washing water go? do you need a holding tank, how big?
Dave.
1972 Piver Trimaran 7.60m moored near Victoria Point QLD Australia.
My Daughter (Above) Described the bosuns chair as a big swing and said it was fun
Old 08-08-2009
Yes Damies, you are quite right re the inverter loss, but as you say still very reasonable.
I guess the dishwasher would have to be close to the galley and at about bench height to really work well.
A dishwasher is also a good tidy and secure place to store dirty dishes, i.e. better than the sink or a drying rack. There are quite a few dishwasher brands with small size dishwashers. Probably also need a very secure closing door, though it might be possible to modify most machines .
Have not researched washing machines, but a front-loader (use a lot less water) combined with drier would probably work best (e.g. Philco maybe, but many other brands also). (Though only use the drier in a marina, the driers heat up a lot but does not need an exit vent, i.e. can be used in closed cabinet.)
Never heard of an automatic washing machine that uses salt water?
Yes you would need a grey water holding tank, as large as possible - say to hold 10 cycles, so 70 litres for the dishwsher and another one for the washing machine.
Old 08-08-2009
Gramp34 is on a distinguished road
Normal cycle:
Water: 7 Litres
Fuse:13amps
Vac: 230VAC/50Hz
Power rating 1080w.
A couple things here. First, what they are calling "Energy" should probably be watt-hours or Kw-hours, which is the right unit for energy.
Since it has a 1000 W heating element, and a power rating of 1080 W (watts is a unit of power), its complete washing/drying cycle probably totals up 800 W-h of electrical energy.
Second, amp-hours is shorthand for energy usage from batteries at 12 volts, not 230. That 800 W-h at 12 v = 800/12 = 66.7 a-h. Xantrex gives an efficiency level of 85% for their Freedom inverters, so this would mean 78.4 a-h drawn from the batteries.
It's not insurmountable, but it might be cheaper overall to invest in a little Honda portable generator and use this to power the dishwasher directly. That'll save the need for a couple hundred extra a-h of battery bank, a big inverter, a big engine alternator and a couple extra hours of main engine use every dishwasher cycle. The little generator would also charge your batteries from regular house loads for less cost than running the engine, too boot.
Tim
Old 08-09-2009
Hi Tim (Gramps34),
you are absolutely right the normal cycle consumes 800 Watt-hours of energy over 1.5 hours. So this mean average power consumption of
800watt-hours/1.5hours=530watts.
So 530watts/12v ~ 45 amp draw.
For 1.5 hrs ~ 67.5ah and so 78 ah @ 85% efficiency.
On Eco it uses 630watt-hours (54mins), so 52.5ah @85%eff ~ 62ah
But yes, quite a lot of power to replace using an alternator, wind gen and solar. So probably need an APU or genset of some kind.
Yes it did seem too good to be true. The heating part of the cycle must consume a lot of power.
I think if guys did the washing up there would be more dishwashers on boats. In any case I think for long term live-aboard away from the marina it would be worthwhile. As would a washing machine.
So the question becomes what size boat and genset/ battery bank would be needed to comfortably generate enough energy (and water) to run this system?
I guess we could round up the required power consumption to include generating 7 litres of water as well as one run of the dishwasher a day to say 100 ah.
A washing machine uses ~45 litres and 1000 watt-hours so 83 amp-hours.
So around 100 amp-hours.
So on average 200 ah every second day would require 100ah perday on top of other energy requirements.
So looks like running a genset or maybe the honda once a day for an hour would the only way to keep up with this sort of drain.
Thanks Tim, I forgot the constant in P=V I is the P.
on board washing machine planzman Living Aboard 4 05-08-2007 06:32 PM
Sailboat was like inside of a washing machine before rescue ... - Canada.com NewsReader News Feeds 0 11-22-2006 01:15 PM
Sailboat in storm was like inside of a washing machine before ... - CBC Nova Scotia NewsReader News Feeds 0 11-13-2006 07:15 PM
Sailboat in storm was like inside of a washing machine before ... - Canada.com NewsReader News Feeds 0 11-10-2006 07:15 PM
Sailboat was like inside of a washing machine before rescue ... - Canada.com NewsReader News Feeds 0 11-10-2006 06:15 PM
