Old 08-07-2009
swarf is on a distinguished road
Profurl LC 32 (info' please)
I have just bought a LC32 reefing gear.with no manual. Have serched the internet without any luck so would be interested to hear from anyone who could give some advice on fitting... What size reefing line? and what side does it leave the drum on? also the oil seal type of bearings seem to have quite a bit of friction on them and have a bit of a rumble when turned by hand.is this OK?.. or Is this last question me being fusy. Thanks,Chris.
Old 08-07-2009
knothead's Avatar
I am certain that Wichard would provide you with a manual. You can contact them here.
Profurl
The sealed bearing shouldn't really make noise. Did you buy this unit used?
The line should exit on the port side of the drum if your sun cover is sewed on the starboard side of the sail and the starboard side of the drum if the cover is on the port.
It doesn't matter which side of the boat the line is led.
5/16" line is probably about right but you can go larger if you remove the core from the portion that wraps around the drum.
Ron Paul 2012
"wikijar"
Old 08-08-2009
Profurl LC 32
Thanks Knothead,Your link worked well,and It looks like all the info' that I will need is there.Yes I got it second hand, an old one that may have some deteriation in the carbon steel bearings,although suprisingly little signs of ware generaly.But I shall fit new ones if it needs them replacing at some time. Also have a Furlex Type C (older one) That has 8mm S/S balls,open races with greasing spaces.All together different mecanism. Chris.
mast info needed for Grumman 8' Dinghy GordonHawk Gear & Maintenance 15 03-29-2012 06:18 PM
James Baldwin's Pocket Bluewater Cruising Boat List sailingdog Cruising & Liveaboard Forum 14 09-16-2011 05:26 PM
Ranger 37 info sanjuan2R Boat Review and Purchase Forum 4 10-13-2008 05:45 PM
Abacos Info... BobbieP Cruising & Liveaboard Forum 4 02-04-2005 03:53 AM
Abacos Info... BobbieP General Discussion (sailing related) 1 01-19-2005 05:23 PM
