Old 11-30-2002
RookieHunter is on a distinguished road
First time up with mast
I''ve seen several references to adjusting the standing rigging for increased performance. However, to the most basic aspect.... The first time up with the mast for sailing, I plan to eyeball for perpendicular from the bow and eyeball from the side to side for perpendicular and then equally tighten the mast. My only estimate has been till it is tight enough that it can only be displaced 1"-1 1/2". After that any changes to one line should also happen to the opposing line (i.e. if you tighten the port shroud line two turns, then tighten the starboard two turns.
Any suggestions would be appreciated.
Old 11-30-2002
Sailormon6 will become famous soon enough
After you eyeball the mast to ascertain that it is more-or-less perpendicular, don''t begin to adjust your shrouds yet. First do the following:
Take your jib halliard and pull it down until it touches the top of your starboard chainplate. You should pull it with just enough tension to take out any sag in the halliard. Then do the same with your port chainplate. That measurement will tell you whether your mast is reasonably perpendicular, or whether it is leaning to one side or the other. After you have done that, then start adjusting the upper shrouds on each side, alternately, making whatever adjustment is necessary to bring the mast to perpendicular. Re-check the measurement to each of the chainplates to make sure that you have it perpendicular.
Next, adjust the tension of your lower shrouds in the manner you describe.
Next, adjust the tension of your headstay and backstay, so that you take out any significant sag. The amount of adjustment should be evenly distributed between the headstay turnbuckle and the backstay turnbuckle. Make sure that all your turnbuckles are locked in some manner, so they can''t back off.
Next, sail the boat. If the boat has excessive weather helm, re-adjust the whole rig so that it tilts slightly more forward. If the boat has lee helm, re-adjust the whole rig so that it tilts slightly more aft.
Those adjustments might not tune your rig race-perfect, but they should get it close enough for general sailing purposes.
These suggestions are general, because I don''t know what specific kind of rig your boat has.
Old 11-30-2002
This is the value of these boards. I am brand new to sailing and information this precise is hard to find in the manuals I am reading.
Thanks for the help!
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
