08-09-2009
the pointy end is the bow
Have you taken it apart yet to see if it has a diaphragm and a fill plug? We had a compass develop a bubble when the diaphragm started to fail. The manufacture said to send it in, as it was a repair that couldn't be done in the field. I ordered the new diaphragm and did it myself and it was simple.
After replacing the diaphragm and getting the correct fluid to top it back off with, I taped a piece of string to the diaphragm. I filled up the compass with new fluid until it was full. then I pulled on the string, which pulled on the diaphragm and poured more fluid in. I held it that way while I put in the fill plug loosely. I released the diaphragm and bit and allowed some fluid to bleed back out of the filler plug while I tightened it down. No bubble.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
