- Quick Menu
08-09-2009
Dinghy decision
Trying to decide between a porta boat and an Achilles aluminum roll up. any advice? Want for a tender for my sailboat.
08-09-2009
Break, curse, fix, repeat
Any advice??????
That's a good one! Any advice indeed. Around these parts you will have no shortage of opinions, and good ones, but make sure you ask your question with enough detail to give people something to go on.
I have all sorts of experience and opinions about dinghies but because of that, know that it depends almost entirely on the size and type of sailboat and the intended use of the dinghy.
More details please...
Aeolus
Gulf 32
Bainbridge Island, WA
08-09-2009
the pointy end is the bow
how will you be storing it?
how many people will you be hauling around?
do you have davits?
will you be rowing or using an outboard?
what size outboard do you have?
will you be towing much?
does your cruising area have rocky shorelines with barnacles/oysters?
all sorts of things to consider. We went through this two years ago and went with a portabote because:
weighs less than the AB inflatable we were looking at, half the price of the A.B., nearly indestructible, rows easier, won't need a davit and can use a smaller out board to move it around. The cons are that it's not quite as stable, it doesn't haul as much gear/weight for the same length, it's ugly as sin.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
08-09-2009
Get the Achilles rollup, will be more stable & versatile
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
08-10-2009
More details
It will usually be two of us with need for groceries etc. We will be crusing between Nova Scotia and the Carribbean. The Portaboate is 10 feet long and the Achilles is 9.6. I intend to power with a 5HP gas engine. Originally looking at Torqeedo but too pricey.
Want to be able to bring tender on boat for rough weather so that is why I am considering Achilles or Portaboat. Am concerned about Achillees durability on rocks around Nova Scotia but like the small space it can collapse to. Dont' know how long it takes to inflate and put together. Portaboat people tell me they can do it in six minutes. thanks.
08-10-2009
1977 Morgan OI 30
One more thought...
Just thought I'd offer our choice. Its too heavy and big to stow on top of our 30'
[ not sure how big your boat is] It weighs #128 lbs and could be hauled aboard w a little effort, but the best part is that it is very rugged and can hold 4 adults while being shorter than your two choices. Just to cover more bases, check out the Portland Pudgy.
My formula for living is quite simple. I get up in the morning and I go to bed at night. In between, I occupy myself as best I can.
Cary Grant
08-10-2009
I too like the Archilles AL roll up and also considered the portabote. A couple of comments. I currently have a Archilles wood floor that is still going strong after more than 20 years of use so that is why I would be going back with the Archilles, however, I did notice that they offer only a 5 year warranty on their product now like most others with the exception of Walker Bay which has a 10 year warranty. Makes me think the Walker Bay product may be better, but no roll up Al floor is available on the Walker Bay.
Secondly, I've had some problem with getting some answers from the porta bote folks and this raises a red flag about getting service should a problem happen with their boat.
For me it boils down to how easy is it to take the boats apart and put back together on the deck of my sailboat. Nothing beats actually putting them together rather than listening to the claims of sales people. As far as performance, I really prefer an inflatable. FWIW, the 10.2 Archilles wood floor with a 5 hp Nissan will plane with me 200lbs with my partner 120 lbs and maybe 20 lbs of gear. Going any distance I think it is important to be able to get up on plane and to be able to take rough weather.
08-10-2009
Well,
There is one more consideration...
'Fun Factor'
A 5 HP will make the Achillies really scoot, especially with one person. I have a 5 Hp on my 9'9" inflatable and I can scoot along at 10mph with my 220 lbs frame. Sometimes I get bored sitting in a harbour swinging on anchor and need a more stimulating activity to change the doldrums. Sure is nice to fire up the dinghy and do some exploring, I can cover some pretty expansive distances with the speed I get, plus I have no problems getting over those rip tides and currents. Just something else to think about.
08-10-2009
When we bought our current boat it came with a porta boat, I have no idea how old it was but, it leaked badly, I ended up giving it to a guy at work.
I'm like the capt above, I like using the dink to explore or just putt around; Mines a PVC coat wood floor rollup which stows nicely on deck under the stay boom, takes maybe 10-15 mins to assemble and pump up
1978 Tayana 37
08-10-2009
I have that exact Achilles rollup boat. You cant get it together in 6 minutes but probably 10 or 15 would do it if you have an electric air pump which you really want (they arent expensive and come in both 12V and 115V models as well as combos)
I have an 8hp mercury 2 stroke on it and it will plane and go very fast with one person. It would also probably plane with two if I were less of a lug.
It fits on top of my 33's foredeck inflated but I usually keep it on davits.
Good boat, would get one again.
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Choosing a Dinghy
Sue & Larry |
Gear and Maintenance Articles |
0 |
10-11-2004 08:00 PM |
Choosing a Dinghy
Sue & Larry |
Cruising Articles |
0 |
10-09-1998 08:00 PM |
