Old 08-12-2009
Indigo Sailor
JoeMcGinty is on a distinguished road
Com Pac 16 Quick Question
I've found a 1980 Hutchins Com Pac 16 in a pasture. Its full of water and pretty sad, but saveable. There appears to be two holes through the transom with 1" (+-) PVC tubing running to them from the bilge. The bilge is full of (what else?) bilge water, so I can't see much. Does anybody know what those holes and the PVC are for. Thx. Joe
Old 08-15-2009
souljour2000's Avatar
souljour2000 is on a distinguished road
Someone probably tried to hook up bilge pumps inside that run out thru the pvc.....not the way you want to go for anything permanent but this might be okay if you need to get 80 gallons out of an old sailboat in a pasture...
Old 09-26-2011
stevelandress is on a distinguished road
It sounds like the PVC was supposed to be part of the self-bailing cockpit. If it's running into the bilge, that's not the original design.
Keel/ballast Question?? Plus Extra Credit Question ;) stephenronning General Discussion (sailing related) 2 03-20-2009 07:25 AM
Another 12v power question TonyInNewportOregon Living Aboard 3 02-17-2009 10:04 AM
Right of Way Question TAK General Discussion (sailing related) 41 06-04-2008 01:37 PM
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
GPS question wallm General Discussion (sailing related) 13 05-30-2004 02:10 AM
