Old 08-13-2009
Jim H's Avatar
Jim H is on a distinguished road
Replacing Winches
We really liked the self-tailing chrome Lewmar 2 speed winches on a boat we just charted, and we're thinking about replacing the winches on our boat.
Currently we have Lewmar 40 standard winches, and they are fairly old. In fact, the base of the winches is beginning to show the bronze under the worn-away chrome on the drums.
Two questions:
If we have older Lewmar 40 winches, is it likely the mounting holes will be the same if we buy new Lewmar 40 self-tailing winches?
Do worn winches have any value to others, as in selling them used or for parts?
The Southampton Boat Show is coming up, and we might get a better deal on new winches there. (Probably around 500 quid each.)
Thanks!
Jim H
London, UK
Aurora, a mighty Cal 20 (Portland, OR)
Southern Rival, a seasoned Rival 34 (Gosport, UK)
Old 08-13-2009
topcat2 is on a distinguished road
Hi Jim
Just received some info which may help u.
The 40 standard winch has bolt holes on a 121 mm dia.equaly spaced .
The 40 self tailing winch also uses bolt holes on 121mm dia , but they are not equally spaced .
Hope thats helpful , can e-mail u more info early sept if you wish , as we are away at the moment
BFN Topcat2
Old 08-13-2009
jarcher's Avatar
jarcher is on a distinguished road
Just about 6 weeks ago I replaced my Lewmar #40 winches with chrome #40ST winches. I too was hoping the holes would match up. It seems like common sense to make them match but, sadly, they do not.
However the old holes are completely covered by the base of the new winch. You can easily find an orientation for the new winch where you can make new holes around the old ones. On my boat there was no reason to fill the old holes. The winches are in the cockpit, bolted to solid fiberglass with an opening under it for handle storage.
Changing the winches was about the easiest job I have ever done on my boat. That said, be careful when you take the old ones off. Don't grab them by the stem because you'll drop them over the side. Ask me how I know Actually, I just lost one bearing.
I have no idea what the old ones are worth, but I am probably going to service them and keep them. I might put them back on the boat to use as cabin top spinnaker trim winches, because my existing spinnaker trim winches are well aft of the tiller end, which makes steering and trimming hard.
I paid about $700 per winch at Defender for mine, which was great at the time and probably still is. If you can get them for $500 each then its a steal.
All this said, you might consider Anderson winches instead. I believe they are made without plastic parts. And occasionally, very occasionally, my 10mm VPC sheets will slip in the clutch. On the plus side, the new winches are very easy to open for servicing and overall have been a great addition. My cockpit is small, so eliminating the need for a crew member to tail has been a big win.
Replacing my winches. grinfax Gear & Maintenance 6 03-02-2009 08:04 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
winches replacing lucy-pj Gear & Maintenance 4 10-22-2001 02:24 PM
