Nuts! - Page 4 - SailNet Community
post #31 of 31 Old 08-21-2009
Originally Posted by Bene505 View Post
Bolt alarms. I think you all need to wire your bolts into a bolt alarm so that after a certain amount of loosening, your fog horn goes off until the bolt is tightened. This will 1) ensure you know when a bolt comes loose, 2) ensure all your neighbors know you have a bolt loose, 3) remove any doubt in your wife's mind that you indeed have a screw loose somewhere.
Dude...that is brilliant!
smackdaddy is offline
NanoStation2 driving me nuts! Writerhall Gear & Maintenance 9 06-10-2009 04:00 PM
Keel nuts drynoc Gear & Maintenance 3 03-03-2009 03:04 AM
Electric set up, am I nuts? alecs123 Gear & Maintenance 12 01-16-2009 10:50 PM
Keel nuts, bolts, loctite, et al.. rperret Gear & Maintenance 1 04-27-2008 11:23 PM
nylon nuts and bolts grampian23 Gear & Maintenance 2 02-20-2004 04:48 PM
