08-17-2009
Interior handholds
I recently replaced the grab rails on the outside with some steal ones and the rails on the inside were through bolted to them so now I have no handholds on the inside. Also no place to hang laundry but fixing the other problem fixes that.
I don't really want to have to drill new holes and through bolt the rails since it will be pretty tough to hide the bolt head on the deck. If I was really lucky I could maybe find something that would perfectly match up to the exterior rails and I could use the bolts from those to mount them.
How strong would it be if I cut out a space in the tack strip and epoxied a bolt into the hole to mount the interior grab rail too? Is there a better way to mount a handle to an interior space? I am in the process of redoing the ceiling as well so I will have an opportunity to do a lot of sanding and fairing so even putting in some blocks to screw into is not out of the question.
I don't want to be falling and grab for it and have it come out though.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 30' Islander Bahama
