08-18-2009
Depth sounder thru hull compatability
I have an S2 7.3 that has a non-functional thru-hull depth transducer (picture attached).
Unfortunately the boat is 3 hours away and I forgot to measure the thru-hull the last time I was out; I won't get back there for another couple of weeks.
So - does anyone recognize the transducer from the picture and happen to know the dimensions?
Or, conversely - are depth sounder thru-hull bungs standardized to fit pretty much any transducer?
I'd like to buy a new system (transducer and display) that can fit into the existing bung.
Also, I've heard it's possible to swap out the transducer with the boat in the water. Does anyone have actual experience doing this? How much water flowed in in the process (seems to me there's lots of pressure)? Anyway to block the hole from the outside while swapping out?
