08-20-2009
Okay, I'll take a crack at it.
It sounds like:
- Dirty fuel
- Air In The Line
Usually when a diesel idles or runs rough it is because of dirty fuel or trace air. Try changing your fuel filters and fully bleeding the air out and see if that helps. If that doesn't help, it could be that the injectors need to be cleaned. If after you change the filters and bleed the air, you're still getting it, look for palces where air could be leaking in such as crushed o-ring, loose bleed screws and clamps, etc.
Also, why do you start your motor and immediately set it to 2000 rpm to "warm up"? I start my motor, let it idle, then ramp up. I can tell when the motor is sufficiently warm to ramp up or put under a small load when the vibrations reduce and there is a perceptive "pitch" change in the sound. On a 70 deg F day, this may take a minute or so.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
