-   -   R&D (PYI) Motor Mounts for Yanmar (http://www.sailnet.com/forums/gear-maintenance/57263-r-d-pyi-motor-mounts-yanmar.html)
jason3317 08-20-2009 02:45 PM
I am considering replacement of the motor mounts for a 2GM20F. Does anyone have direct experience with the R&D mounts marketed by PYI?
http://www.pyiinc.com/images/pdf/rd/...R%20YANMAR.pdf
In my experience, the aftermarket can come up with some good stuff that offers better performance than OEM...but not sure in this case.
Thanks in advance.
Jason
SVCarolena 08-20-2009 04:10 PM
No personal experience, but what I've read about using aftermarket mounts on Yanmar engines does not favor aftermarket. I plan to replace the mounts on our 2GM this winter and have already decided to bite the bullet and go with OEM. I know they are very expensive, but from my research are worth it based on the cost to hassle ratio.
scottyt 08-20-2009 05:07 PM
i have pondered the same thing. a local yanmar place said the pyi are fine but they are stiffer so you will get more vibration in the hull. i will wind up putting them in at some point. at some point someone will tell ya the yanmars are enginered with the motor and they are different for front and back, and you need to use the yanmar mount
jason3317 08-20-2009 07:44 PM
After thinking about it a bit...I am going with the Yanmar OEM mounts. Safe bet that they will work, right :-)
SVCarolena 09-03-2009 05:34 PM
Right! Let us know how it goes and if you see any vibration improvements after the replacement.
SVCarolena 03-12-2010 04:38 PM
Jason - any update on the new mounts?
jason3317 03-14-2010 10:31 AM
Yes. The new (OEM Yanmar) mounts were installed last season. Although it didnt ultimately fix the vibration issue, I am satisfied with the result. I don't recall the total cost, I think it was 10 hours of labor + $250 parts cost.
I noticed the new mounts greatly improved the drivetrains ability to transfer power, plus the engine is rock solid stable at crusing RPM.
Jason
byrd151 03-14-2010 01:03 PM
I have the same engine in our Islander....how do you decide it's time to replace the mounts. It has crossed my mind also. This one does a fair amount of movement when idling/low rpms. Once moving along it does seem pretty smooth. Just wondering. Thanks
Thisisus
Islander 32
Mobile AL
scottyt 03-14-2010 01:11 PM
well the spec for the stock mounts is to check yearly and replace every other other year IIRC. the stock mounts dont last long if you use yanmars info for when to replace them
jason3317 03-15-2010 06:46 PM
Admittedly, my mounts appeared to be old, possilbly original to the boat (1988).
I think I would go 5-10 years before replacement.
The starboard rear mount, I think, bears alot of torque on my installation.
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
