-   -   Autohelm 1000 (http://www.sailnet.com/forums/gear-maintenance/5729-autohelm-1000-a.html)
fbiery 12-05-2002 08:55 AM
Autohelm 1000
I have an older Autohelm 1000 and apparently have a loose connection at the cord. The unit cuts out, but when I play with the cord where it enters the housing, it works. I want to open up the case so I can re-do the connection, however, the 6 screws that hold the case together have a completely unique head. Does anyone know what kind of screwdriver/nut driver is needed to engage these screwheads?
geohan 12-05-2002 01:16 PM
Autohelm 1000
Harbor Freight has a cheap set of bits to fit hex socket screwdriver handles. It includes several styles and sizes, one of which might fit.
Chears, George
WHOOSH 12-05-2002 02:24 PM
Autohelm 1000
F:
Visit the Raymarine site and search their users'' help forum; the answer may be there. If not, you can post your query and they will answer it. Another (perhaps parallel) query to their general email address might work, too.
I think Raymarine has an excellent Q&A Forum for these kinds of things. Reading some of the problems that are addressed and using the functional search engine, I''m left wondering why this isn''t more often seen.
Jack
pirateofcapeann 12-06-2002 06:06 AM
Autohelm 1000
If memory serves, theyíre either T10 or T15 Torx heads. If you have to ask that question, Iíd ask if you have the expertise to go inside of that thing with out doing further damage. Thereís quite a bit of sensitive parts and circuitry involved as specially around the compass head and that red trim around itís midships is actually a seal which can be a bit of a bother to properly put back in place. The plastic in those older ones can get quite brittle and they donít take too kindly to flexing or being forced. Iíd recommend taking it to someone with a background in repairing electrical and mechanical items. It may not be rocket science but itís $400 in the trashcan if you screw it up!
sailnby 12-07-2002 05:28 PM
Autohelm 1000
The Pirate is right unfortunately. I work on all sorts of electronics and have experience with that unit. If there is anyway to not open the controller, don''t. The boards are connected together U.K. style and very prone to failure. The dodge switch will fall out, the O-ring will need to be replaced, they are tough to get back together correctly and you will most probably end up with an intermittent new problem. I wasted 6 hours on one of those things with a similar problem. If you must crack it open and need help, drop me a note.
WHOOSH 12-08-2002 03:12 AM
Autohelm 1000
Greg, please look at the note I left you on the Sailnet Message Board. Thanks for any comments you can offer...
Jack
Lucky1 10-07-2015 05:55 PM
Re: Autohelm 1000
Hey sailnby
I just saw one of your old posts from 7/2000, wonder if you are still working on Autohelm 1000's or if you are retired. Please send me an e mail if this message reaches you.
Karl
lucky65@sbcglobal.net
jimrafford 10-08-2015 01:53 PM
Re: Autohelm 1000
Contact Dan Gerhardt. Email c250@mydurango.net
He has helped me out in the past
Jim
Lucky1 10-09-2015 02:38 PM
Re: Autohelm 1000
Hey Jim
E mailed Dan but he no longer has a shop nor does he repair any autopilots any more, he now bought a power boat and has too many projects to help me out. So if you have any other suggestions please let me know. My motor is good both directions, and i get the beep sound when pushing the buttons, just no response from the extension rod.
PS I did get a burning smell when i opened the case
Karl
jimrafford 10-09-2015 05:52 PM
Re: Autohelm 1000
That's unfortunate. He was a great help to me.
Hard to get anyone to work on older units. They just want to sell you something new.
If you have a soldering iron hit all the connections on the circut board. Otherwise have a running search on ebay.
Jim
